alt. prolly killed battery?
Old Feb 6, 2004 | 01:19 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
I got a question. When I turn my key to accessory position it reads around 11-12 volts. But now when I turn the key instead of starting it just woes and the volts go down to the red zone.
Is this my alternator? I just bought a new 80.00 battery so I know its not that. What about my starter could it be my starter?
Nate
Old Feb 6, 2004 | 01:22 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If the car isn't starting, it could be a bad starter, or worse yet, a froze up engine. Alternator has nothing to do with the voltage drop during starting.
Old Feb 6, 2004 | 01:26 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
sounds like the batt. has a bad cell (even on new ones) or you have a bad connection, causing a large voltage drop, check the ground and starter connections
Old Feb 6, 2004 | 08:48 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Ill check the connections tommorow. My mother got it jumped tonight and even as she was warming it the volts were dropping. Im guessing either like you said its a bad connection, or the alternator is replenishing the volts. Either way I dont think my alt. is good and Im gonna end up buying a new one.
Old Feb 7, 2004 | 11:23 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Hey guys I put on a new alternator and the volts shot right up to around 15 again. Wish my luck that it doesnt decide to die again for some odd reason. Thx for the suggestions.
Nate
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
