intake gasket sealing
Old Feb 7, 2004 | 11:29 AM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
I am about to seal up my carbed 350 with new gaskets on the intake, and wondering how much sealant to use??? and u just use sealant on the engine side of the gasket and not the intake right???
Old Feb 7, 2004 | 12:17 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: intake gasket sealing
I use High tack on both sides. Just brush on enough to cover the gasket.
Old Feb 7, 2004 | 02:58 PM
ede's Avatar
ede
coated gasket between two machined surfaces shouldn't need sealer. you might want to use some rtv around the water ports. i like to coat the long gaskets with k&w copper spray.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
