Shaving down heads?
Old Feb 7, 2004 | 02:43 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
Shaving down heads?
Can 64cc heads be shaved down to 54cc for more compression??
Old Feb 7, 2004 | 03:46 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
no because the intake will not seal to the heads right it will be alot of gap.
Old Feb 7, 2004 | 04:24 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Can stock 84 305 heads be shaved down to 52cc ??
Old Feb 7, 2004 | 05:21 PM
ede's Avatar
ede
the amount of metal that can be removed depends o nthe amount there is to start with . with that said yes they can be milled, if it's past a certin amount the intake will need to be machined as well to fit the head and prevent a unsealable gap.
Old Feb 7, 2004 | 05:22 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
yes I've done it. Got exactly that , 52cc's
You can mill down to just before you get to the spark plug boss on 416 castings.
Didn't have to cut the manifold face (cause I enlarged the manifold bolt holes) and the port roofs were raised by porting) but did cut the bottom of the manifold where it mates with the china walls on the front and back of the block. (did it by hand with a 7" grinder and 60 grit disc.)
Old Feb 8, 2004 | 09:27 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
o so its not just bolt on and go. what kind of compression increase would you get from using 52cc heads?
Old Feb 8, 2004 | 09:34 AM
ede's Avatar
ede
kb has a calculator on their site, sorry i lost the link.
Old Feb 8, 2004 | 12:55 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
You can get a set of offset head locating dowels that will re align your ports and bolt holes after milling or block decking.
Competition products has them.
Old Feb 8, 2004 | 07:19 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yea I found a set of 305 heads ported 1.94 1.50 valves springs and shaved down to 56cc for $430 sounds pretty good.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
madsv1000
Aug 20, 2015 06:45 AM
