89 iroc problem
sounds to me like an IAC (idle air control motor) that is either very dirty or just worn out. That is a very common problem, but then again so are flakey MAF's. The MAF problem or even vacuum leaks should set a code eventually, but many times a faulty IAC will never set any code.. the idle just goes up & down, up & down and engine sometimes will die in gear.
On a rare occasion I have seen idle fluctuate like that because the tranny was 2 qts low on fluid (big air pocket in the TC).
Let us know what happens.
good luck
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, single 3" Borla exhaust, Linginfelter-TPI camshaft pulls 17" vacuum solid. N/A runs 10.9 @124, Crack-runs 10.3 @135... haven't run at track since Oct-99
good luck
mustangman65_79
Aug 11, 2015 03:17 PM
