people who have high lift cams?
Old Feb 8, 2004 | 11:56 PM
icebird_1981's Avatar
What rpms are u around in park? and what rpms while in drive?? with a high lift cam is the rpms suppost to be alot higher in park? (past 1k?) when i adjust the rpms lower while in park as soon as i put it in drive rpms drop to low and stall out. am i haveing a problem some place or is this perfectly normal with a higher lift cam? my mods are in my sig.
Old Feb 9, 2004 | 02:39 AM
ronterry's Avatar
Car: '94 Corvette
Hey 'Icebird', I have a pretty lumpy cam (Comp XE284), and I run it about 8-9 in gear, and about 1K out of gear.
I have my initial timing (about 16°), so it behaves nicely.
Might check your timing a little.
Oh yea, the 284 has a 240/244 duration. Hydraulic-Flat.
Ron
Old Feb 9, 2004 | 04:15 AM
EvilCartman's Avatar
Car: '82 Z28
I'm running a 294 solid lifter cam... ( Duration 248/248 lift .525 /.525) and I've got it idleing at around 650-700 in park or drive (doesn't really change due to loose converter) Base timing is at 19°.
beastin91rs
Oct 9, 2015 07:38 AM
bdads
Aug 24, 2015 06:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Hello, Michael
Aug 20, 2015 03:19 PM
anesthes
Aug 8, 2015 09:37 PM
