Something wierd on end of spark plug HELP!!!!!!!!!!
Old Feb 4, 2001 | 01:42 PM
gruveb's Avatar
Car: 1989 IROC-1
I've got a "new" 84 Z, and am giving it a routine tune up. I'm changing the plugs........and two of the plugs came out with this cap on the end of the plub. It's threaded, same thread as the plugs themselves, and has a small hole.... The plugs appear to be fine, but how is this going to allow my engine to fire correctly?
What in the world is this? Any ideas?
Old Feb 4, 2001 | 01:46 PM
CamaroMike's Avatar
Sounds like a plug saver to stop an oil burning engine from getting fouled plugs.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Feb 4, 2001 | 01:47 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They are called "anti-foulers" and if your car is burning oil or somthing, it prevents the burnt residue from buiding up on the electrode causing it to foul out.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 4, 2001 | 02:23 PM
gruveb's Avatar
Car: 1989 IROC-1
That would make sense...the engine needs to have the valve seals replaced, but I used that as a perfect excuse to upgrade to some vortec heads......Thanks again.
Old Feb 4, 2001 | 03:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
How does a "new" 84Z need valvestem seals and a tune-up?
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Feb 4, 2001 | 04:04 PM
gruveb's Avatar
Car: 1989 IROC-1
Well, new for a whopping $1500.00 and been stored for years. T tops, 5 speed, centerline rims, decent tires, flawless interior. It's "new" to me.....................
Old Feb 4, 2001 | 04:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Oh, OK, just wondering.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Feb 4, 2001 | 04:21 PM
gruveb's Avatar
Car: 1989 IROC-1
Also, something "new" to throw my money into instead of the bank where it belongs.
"Boys and their toys"
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
