Block boring
Old Feb 4, 2001 | 08:13 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Block boring
How much does it cost to have a block bored?
Old Feb 4, 2001 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It varies from place to place, and what else you're having done at the same time... expect $120-175.
Specify that it be done with a torque plate, so that the block gets bored with the same distortions that bolting on a set of heads would create.
ICON Motorsports
Old Feb 5, 2001 | 05:23 PM
ede's Avatar
ede
8 dollars a hole around here, plus 40 to clean the block, 15 or so for freeze plugs and 25 for cam bearings
ICON Motorsports
1st & 3rd
Old Feb 5, 2001 | 05:30 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
I'd also recommend ensureing that the same type of head fasteners you're going to use are also used during the boring/hining process. Any machine shop worth it's honing fluid will do this, but you gotta be sure.
Studs distort the block in a different manner than do bolts. Although the difference is slight, it can make a difference in ring sealing.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
customblackbird
Oct 1, 2015 04:30 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
