Throttle Body Bypass Question
Old Feb 18, 2004 | 03:33 AM
Ravenshorn's Avatar
Car: 1992 Firebird Formula WS6
Engine: LB9 305 TPI
Transmission: TH700R4
Hey all. I read an article with a rouph sketch on a firebird page about a throttle body bypass for improved throttle responce. It was described by a "how to" for a 86 trans Am and the picture used seems different then mine. It was a TPI Setup like mine is (1992 Firebird TPI 305...mine) but looked different with the hoses. I was wondering if anyone here could tell me exactly what I need to do on MY car to get that improved throttle responce. Thanks all!
Old Feb 18, 2004 | 05:40 AM
ede's Avatar
ede
remove the coolent lines going to the TB and connect the two lines together
Old Feb 18, 2004 | 01:37 PM
Ravenshorn's Avatar
Engine: LB9 305 TPI
Hi, well the trouble i'm having is figuring our which two of the hoses there are the right ones. I've got The large one going from the Radiator to the thermostat housing...I"m assuming that's NOT it, I've got a very small tube section right to the left of that that just forms a U (right underneath the Throttle body on my TPI) Then there are more to the left of that, on the left side of my Throttle body. Then there are the assortment of heater valve hoses and junk all to the left of those as well. So, is the one I'm looking for the VERY small ones directly left of the thermostat housing, or are the the set of hoses left of that??
Old Feb 19, 2004 | 12:20 AM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...ntbypass.shtml
Old Feb 19, 2004 | 02:33 AM
Ravenshorn's Avatar
Engine: LB9 305 TPI
Thanks for the pic That link you gave is the same link that I was originally referring too and that tube on the far right is strange to me because the only thing I have similar to that is my radiator tube going to the thermostat housing...so the picture doesn't seem exactly like my car...your picture however shows a different spot than that link does....those tubes you have connected together...One is from the heater control valve right? And that one coming from right to left under your TB...where does that one connect to so I know which tube to remove....Thanks and sorry if I"m not catching on to this quicker...
Cheers
Old Feb 19, 2004 | 06:57 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The tube on the right connects the port on the intake base to the port on the bottom of the throttle body. Coolant flows from the base, then through the throttle body, then to the heater valve.
Old Feb 20, 2004 | 10:33 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The one that you noticed yourself as being U shaped. Remove the U, and connect the hose in the above pic to where the bottom of the U was connected.
Old Feb 21, 2004 | 11:32 PM
Ravenshorn's Avatar
Engine: LB9 305 TPI
Sweet Thanks Guys
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
