oil pan
Car: 1990 RS
Transmission: TH-350
oil pan
im dropping in a pre 86 350 in a 90 camaro, is there a special oil pan i need? i read some post about dipsticks being in the way and what not. just wondering if everything will be ok. the motor came out of a 79 monte carlo, so i know the oil pan fit in it. any suggestions?
Car: 1990 RS
thanks man, also i bought the felpro ks2600 gaskit kit so i can bolt my motor back together. does this kit include everything i need? thanks again man
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would check cross member clearance. It should be okay but those are always your famous last words. I would try to compair it to a stock f-body pan just to make sure. If it is to close you may not be able to run a y-pipe.
