Aftermarket ignition module?
Old Feb 6, 2001 | 08:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I believe my ignition module is bad, now should I just run down to the local autoparts store and get a no-name, go to the dealer and get an AC Delco or buy aftermarket like Accell? I have heard stock modules are no good for high performance engines. I have a modded 383 TPI.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Feb 6, 2001 | 09:23 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
IMO they are all the same. If you live near an autozone get one there. $20 and a lifetime warranty! I stopped in at A&A (I don't know what part stores are around, but A&A is drag race Joe Amatos store {Key Parts}) and they wanted $80 for a Standard replacement!!! What are they smokin'!!
I got the accell one and sent it back. Improvements are more in the coil.
Old Feb 6, 2001 | 10:03 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
dont buy no names
the best is acdelco or accel
either way there will be little improvement in performance from just a module change.
racing ignitions eliminate this module because generally it sucks for high rpms
Old Feb 6, 2001 | 10:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get one from Performance Distributors. Also get their coil.
A speed shop I know of that carries both products A-B'd a DUI against MSD on a car on their chassis dyno; the Perf Dist DUI made 7 more RWHP than the best that MSD could do.
ICON Motorsports
Old Feb 6, 2001 | 10:50 PM
Vader's Avatar
John,
The Standard Products high-energy modules are a bit pricey, but will sustain primary switching currents and dwells at higher RPMs than the Delphi amplifier. The Accel is probably just as good and is usually a little cheaper.
I don't know why, but I would be a little wary of a generic replacement module in a higher performance application. For most street driving, it would be just fine, but higher RPMs and the resultant short dwell/high currents might be more than a generic unit is designed to handle. I have no data to support this opinion, just a gut feeling that the low-buck replacements aren't up to the task of a more demanding installation. Price is everything in the replacement market, and cutting corners is very likely on low-end components. I could be way off on this.
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Old Feb 7, 2001 | 09:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
FYI, Holley's also making a few modules for our distributors. Go to http://www.holley.com , visit the Annihilator link, and go under "parts & accessories" to see:
http://www.holley.com/HiOctn/ProdLin...A/891-101.html
http://www.holley.com/HiOctn/ProdLin...A/891-102.html
http://www.holley.com/HiOctn/ProdLin...A/891-103.html
http://www.holley.com/HiOctn/ProdLin...A/891-104.html
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 7, 2001 | 02:31 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've been through a lot of the cheap auto-zone ignition modules. They seem to go bad quicky in high performance applications. I didn't have much better luck with the Accell ones either. I bought an MSD ignition module last year and haven't had any problems since, it seems to be very good quality. It was expensive but better than replacing it every couple of months.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Feb 7, 2001 | 03:34 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
I havent been a member here all that long, but i have been here long enough to realize that Vader know his s***. if he has a "gut feeling" about something, then you can be sure its probably true
just my opinion though
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
MUSTANGS SUCK
Old Feb 8, 2001 | 05:35 AM
Engine: 4.0L
Thanks again for all the replys.
pjsparts
Oct 29, 2025 06:39 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
BLK87Z
Sep 18, 2015 11:29 PM
