What kind of heads are these??
Old Feb 7, 2001 | 06:16 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I've got a set of heads in my garage that a friend left several years ago still in the box brand new.
They're for a Chevy 350 and are 64cc - angle plug.
On the box, it has P/N 1112B Sportsman 200 64cc cast iron.
The numbers stamped on the heads under the valve covers is:
L13
M
just like that, then on the front part still under the valve cover is:
I-037
Thay were originally purchased from "Auto Parts Co." in Marshall, MI.
Any idea if they are good performance heads, better than L98's or just stock? Seems like he said they were some sort of performance heads is why he was keeping them, but he's long gone and moved away several years ago and left them.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Feb 7, 2001 | 06:20 PM
MrF-body's Avatar
i needs a set of heads, if you're gonna sell them. PLEASE email me and let me know!!
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
paid $600 at a junkyard for it (i had to save it)
Old Feb 7, 2001 | 06:40 PM
ede's Avatar
ede
sound like dart heads, but i can't find a catalog to check. i'd like them too, maybe.
ICON Motorsports
1st & 3rd
Old Feb 7, 2001 | 06:46 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I believe those are World Products Sportsman 2s. they are darn good heads. My friend ahs them on his 355 and it really screams.
Old Feb 7, 2001 | 10:32 PM
2QUIK6's Avatar
Would they work for an L98 build up with TPI? Better than the Vette L98's?
They don't have the EGR passage, its block off a few inches down in the head, the EGR port is a "dead end".
Old Feb 8, 2001 | 12:24 AM
Basett Racing's Avatar
They are probably Dart II Sportsman heads, because I have bought a couple of sets World Products Sportsman II's, and they have a different. They are almost exactly the same head as the Sportsman II, but the combustion chamber is a little better in the Sportsman and they flow slightly better.
Either of them are better than a L98 head. They have 2.02int 1.60exh, flow much better than L98's and they are a thicker head which will be forgiving to overheating and have a lot of porting potential. My brother has a full size, 3800# 78 GMCpickup with a 350, 10:1 CR, GM 1st design off-road cam (67-69 DZ 302 SCCA cam) Bowtie intake, 750 Holley, 3000 convertor, 4.11 gears, regularly driven Street-machine w/ a set of Sportsman II's and it turned a 7.78 at an 1/8 mile a week ago. That is a low 12 run in the quarter, in a heavy a$$ truck, so yeah, those are good heads.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 8, 2001 | 12:26 AM
BTW, the heat crossover can be drilled for use with EGR.
Bassett Racing
Old Feb 8, 2001 | 08:36 AM
Polecat's Avatar
Look under where the casting numbers should be(under valve cover) and look for a big W by itself. If so, they are Sportsman's.
By the way Basset Racing, those are some REALLY impressive times for your brothers truck.Nice web site!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
[This message has been edited by Polecat (edited February 08, 2001).]
Old Feb 8, 2001 | 09:47 AM
2QUIK6's Avatar
Polecat, yes, they do have a big 'W', with a 9 and a L13 just above the big W.
Will these work with a '92 TPI setup?
Thank for all the info.
Old Feb 8, 2001 | 04:32 PM
2QUIK6's Avatar
I see the center bolts are angled the same as the corners, but on the TPI intake the centers are more straight up and down.
Maybe with some drilling out onthe intake and studding the center holes it might work?
Anybody done this on their TPI intake?
That is if it can be done without interfearing with the runner base...
Old Feb 8, 2001 | 04:48 PM
Thanx Polecat, You can see the truck in the first site in my sig.
Bassett Racing
Old Feb 9, 2001 | 08:33 AM
Polecat's Avatar
2quik, Not for sure without actually seeing the head, But call them at www.worldcastings.com
Basset, yea, I checked it out. Darn nice truck and times! What's in for future plans for it?
italiano67
Dec 11, 2016 09:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 07:57 PM
novaderrik
Aug 10, 2015 12:44 PM
