Specs on Stock V8 305 engine from 1988 camaro's
Old Feb 8, 2001 | 08:30 PM
Jims83TA's Avatar
I am wondering what the general specs on the V8 305's that came in the 1988 camaro's. Just wondering the horsepower and torque. The car is completely stock. Thanks.
Old Feb 8, 2001 | 08:33 PM
Vader's Avatar
Jim,
What fuel system? What transmission? What special packages?
It all matters, since the manuals had a bit more HP and torque, and the TPIs had more power than the TBIs.
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Old Feb 8, 2001 | 08:50 PM
MrJ's Avatar
MrJ
its easiest to just answer the question.
305 TBI: 170hp, 255tq
305 TPI automatic: 190hp/285tq
305 TPI 5 speed: 210hp/285tq... varies +/-5hp I believe depending on whether its a Firebird or Camaro.
The 305 TBI was the standard V8 in the Sport Coupe and IROC-Z. The 305 TPI was available only in the IROCs.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Jims83TA's Avatar
I'm sorry. I dont know the specifics. I don't own the car. A friend of mine is looking into buying a 1988 camaro. I personally own a 1983 Trans am. The guy that was selling it to him didnt know that much about the engine i guess, because all he said that it was the smaller 305, so im guessing that it isnt the TPI. It is an automatic. I dont think it has any special packages, and I'm pretty sure it is an RS. Please just give me any info you can, regarding any 1988 camaro. Just give me an estimate, thanks.
Old Feb 8, 2001 | 09:07 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
The specs should be in the Tech Data section on the home page. If it's an RS, it's most likely the Throttle Body Injection 305 (TBI). 170hp @4000rpm, 255 ft-lbs @2400rpm. It's weird that they don't really list an RS for 88 in the tech data. Is that right?
Yep, just checked, no RS for 88, sport coupe available with V6 or V8.
[This message has been edited by RednGold86Z (edited February 08, 2001).]
Old Feb 9, 2001 | 04:32 PM
Yarnboy's Avatar
BTW, the '88 305 TPI 5 Speed is 220hp and 290 lbs/ft. I am a little defensive aabout my car..sorry
  • Red '88 IROC 5 Speed 305 TPI w/3:08
  • Dual Friction Centerforce Clutch
  • Accel 300+ Racing Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • Accel U-Groove Plugs
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Hypertech Chip
  • Hypertech Airfoil
  • Removed, Then Re-installed (out of fear) MAF Screens
  • Gutted Air Box
  • Best E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 MPH 93.91
  • Best 60' 2.17
Old Oct 3, 2013 | 10:03 PM
Unlimited's Avatar
Re: Specs on Stock V8 305 engine from 1988 camaro's
I'm selling one of these 305 TPI engines from a 1988 Camaro irocZ, with the automatic transmissions still attached, is there any easy way to see if the engine is still good? It was pulled in 99 and stored in the garage since.. any ideas?
Old Oct 3, 2013 | 10:28 PM
Unlimited's Avatar
I was told to add fluids to it and then use a breaker bar to see if you can turn it.. Is this a safe way to at least see if it's seized? It's only got around 30,000 miles on it so I'm thinking it has to be good..
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
Billy Decker
Sep 4, 2015 03:46 PM
Formula_88AE
Sep 3, 2015 01:47 PM
