Grind my 5.7 rods again for the 406?
Ive got a quick camshaft question that is driving me crazy and holding up my motor progress. Last year i ran the Comp cams extreme energy 268/280 duration .477/.480 hydrolic camshaft....and i had to grind my connecting rods in places for the cam to clear. This year i got new vortec heads, and i want to put in a comp cams extreme energy 284/296 duration .507/.510 lift hydrolic camshaft. I have heard that once you grind your rods once you dont have to do it again... is this true? I realize the cam cant get that much bigger cause it wouldnt fit through the opening to get the camshaft in the motor..... any ideas guys?
Car: '82 Z28
Engine: 350HO
Transmission: M4
well assuming both cams have the same base circle, the old cam had a lift of .32" and the new cam has a life of .34" so thats 2 thousands difference.
But as RB said, theres no sure way of telling without mocking it up. A alittle extra time spent now is better than a rebuild later
yeah.... true i was just trying to decide whether or not it would be worth spending the extra money on a small base circle cam or not. i think i will just get a reg one and if i have to grind a little more on the rods. Thanks guys
Car: '82 Z28
Engine: 350HO
Transmission: M4
Originally posted by BIRD91ZRAG
Scottland- Your math terminology is a little off...The difference would be 20 thousandths, or two hundredths. (about the thickness of a paper clip.)
I knew that didn't look right. thx for catching the slip up
so if the old cam cleared with no problems and i already have all the pistons and rods out i should just go ahead and grind a little more off every rod where i ground them before and stick them in one at a time with the cam in and see what happens. A paperclip dosent seem like too much but it only takes a little bit
Car: '82 Z28
Engine: 350HO
Transmission: M4
i wouldn't go to the trouble of grinding them first, but yep, test fit them each one at a time with the cam installed, and turn the crank to check for clearnence.
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
