Code 36 and 45
Old Feb 29, 2004 | 02:46 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
Code 36 and 45
What codes are these and what can I do to fix them?
Old Feb 29, 2004 | 07:27 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
45. Oxygen sensor rich
Sounds like a bad MAF sensor to me.
Old Feb 29, 2004 | 08:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello ZROC86,
You have some information in your e-mail box.
Old Mar 1, 2004 | 09:41 AM
ZROC86's Avatar
Transmission: A4
Hey thanks for those Trickster! They should come in handy. I just replaced th O2sensor like last week or so.
Old Mar 1, 2004 | 01:02 PM
ZROC86's Avatar
Transmission: A4
woops!
Old Mar 1, 2004 | 01:03 PM
ZROC86's Avatar
Transmission: A4
When I installed the new o2sensor I obviously didn't have the battery disconnected long enough for it to clear the codes. I did it again today and now only have code 36.
Would a new MAF solve the problem?
Old Mar 1, 2004 | 04:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, I don't believe that replacing the MAF will solve your problem. Read through the chart I sent you, it tells you to check the wiring and it could be a possible bad ECM or MAF sensor power relay. Not the MAF Sensor itself.
Old Mar 12, 2004 | 08:43 AM
ONEEYEFUL1's Avatar
Car: 88 Iroc-Z L98
same problem code 36.
Hey Trickster,
Could you email me that chart, I'm having the same problem.
Thanks....Rob
Old Mar 12, 2004 | 09:22 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Rob,
You have a package in your e-mail.
Old Mar 12, 2004 | 08:12 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I used to get a 36 all the time till I replaced the MAF burnoff relay..
I also used to get a 45 O2 sensor rich when driving above 110 kph....
but it seems to have gone away.... and this happened for a few months after putting a new O2 sensor in..
Old Mar 12, 2004 | 08:18 PM
Nixon1's Avatar
You did reset the ECM after installing the new O2 right?
Old Mar 12, 2004 | 08:48 PM
waltersb's Avatar
It had been reset for various reasons a few times... and it still came up...
The 45 code...
what was funny was, it would come on, for a bit, then some city driving at 50-60kph and then it would go away...
Old Mar 12, 2004 | 08:55 PM
Nixon1's Avatar
That's odd. But stranger things have happened.
Old Mar 12, 2004 | 09:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can get a code 45 at times if too much fuel is shot into the engine causing the o2 sensor to temporarily read rich. The same thing can happen if the fuel pressure regulator is set too high.
Old May 14, 2004 | 10:41 PM
jl0gue's Avatar
Car: 89 IROC
Transmission: 5 Speed
I just started getting the code 36 too. I tried to find more information on the MAF burnoff sensor in my manual but I couldn't find anything. Where is the sensor located?
Old May 14, 2004 | 10:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It isn't a sensor, it is a relay mounted on the driver side firewall. Here is some info on the code 36 problem you have. BTW, welcome to the board.
Old May 14, 2004 | 10:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
part 2
Old May 14, 2004 | 10:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
part 3
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
