Valve Stem Seals, older heads
Old Feb 29, 2004 | 05:51 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
I bought a set of heads from a local guy around here. The casting number says they're made somewhere betwen '69-'76. I don't know what valve stem seals to get. I don't want to have to do any machining to make valve stem seals fit, so I'm thinking to just put the umbrella seals on. I don't know what size to get. When I got the heads, they only had the little rubber o-ring on them, no valve stem seals though.
I hear the positive seal valve stem seals require machining on the valve guides to install, so those aren't really an option. Thanks for any input.
Old Feb 29, 2004 | 06:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you don't want to machine, then the umbrella seals are probably your only option. There's only one part # for a set of them that I know of. They fit 11/32" valve stems, and guides up to about .600" OD.
gta90
Sep 15, 2015 04:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
