Oil in intake?? How?
Old Feb 12, 2001 | 12:12 PM
UVA3rdGen's Avatar
This question refers to my 92 305 TPI and my buddies POS 93 3.1 V6. How does oil build up in the intake? It does not seem to make intuitive sense to me. My cars plenum was coated with a think carbon residue, but my buddies car had oil leaking out of the intake from the throttle body when he turned the car off. I assume what caused the carbon in my car was the EGR valve, but what could cause oil to come up into the intake like that? Bad valve stem? Why would the oil and carbon not get sucked into the cylinders? How could the oil come all the way up to the throttle body?
Old Feb 12, 2001 | 01:46 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
[This message has been edited by Monty (edited February 12, 2001).]
Old Feb 12, 2001 | 03:14 PM
The ODB's Avatar
It comes from the PCV that enters the passenger side of your throttle body.
ODB
Old Feb 12, 2001 | 09:12 PM
UVA3rdGen's Avatar
Does that mean his PCV valve is bad?
Old Feb 12, 2001 | 09:14 PM
mtx28's Avatar
or... oil gets on my intake from under the valve covers, put some new gaskets in
Old Feb 12, 2001 | 10:43 PM
Vader's Avatar
Most likely blowby gasses returning up the PCV vent tube to the throttle body. Thats a sign of excessive ring wear and poor sealing, or excessive boost pressure from a blower or turbo.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 12, 2001 | 11:32 PM
UVA3rdGen's Avatar
Ahh, that makes sense. Thanks for the info guys.
Old Feb 13, 2001 | 12:39 AM
burnoutrpm's Avatar
how many miles are on the engine???
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 13, 2001 | 08:09 AM
UVA3rdGen's Avatar
Mine = 22 thousand
His = 89 thousand, the last 100 miles with out much oil in the crankcase and overheating.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
