what cam for my setup totally confused help!!!
Old Feb 12, 2001 | 03:17 PM
hookin88formula's Avatar
ok its that time of the year where i put the snowmobile up and start looking for parts for my car again.. i want a cam for my car when u read my profile u will see the mods i have done.. i plan on making my own cold air induction,gears,and a shift kit this year and the cam.. but i dont knwo what cam is good or what numbers to look for as in seperation, lobe and stuff like that. also i want to put a afpr on but other then that i have no idea what to look for i just know that i want a real lumpy sound the big block sound i guess but dont want to acrafice hp so anyhelp would be great thanks..
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Feb 12, 2001 | 06:04 PM
any1 help plz??
Old Feb 12, 2001 | 07:02 PM
come on someone has to know help me here please!!!!
Old Feb 12, 2001 | 07:57 PM
Blown GTA's Avatar
What you're looking for is the LT-4 hot cam. Check out Tom Keliher's webpage for a sound clip of how this cam idles. I think you would like it.
Old Feb 12, 2001 | 09:08 PM
ok thanks do i have to buy anything else when i do the cam? i am having a buddy help me do this but just wana know what i will need what kindof performance gain will i acheive??
Old Feb 12, 2001 | 09:29 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
you will need the Lt4 valve springs and a set of 1.6:1 rockers. Also Im pretty sure youll need a custom chip - not sure. Other than that you will have a kick *** ride that will respond well to induction mods like shorter runners and a larger throttle body
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Feb 12, 2001 | 09:46 PM
hope no custom chip i had been told by someone that 88 came with stock 1.6 rockers? was i told wrong? let me know thanks!! how much should i look to spend? or actually how much should this little project cost me?
Old Feb 13, 2001 | 07:27 AM
any1 else can u help me here? i want to order this and get this going if it isnt going to be a big perf gain then i wont do this right away but while i have the intake and plenum off i figured i might as well try to get it done!! so help is much appreciated
Old Feb 13, 2001 | 11:26 AM
Beefy89's Avatar
The first thing I would do is heads and a cam.As far as which cam,it depends on what you want the car to do.If you drive the car daily then you might want a cam that's not so radical(up around .500 lift).If you just cruise with it and/or race it at the track,then you might want a cam with a lift over .500".Keep the lobe seperation at 112 or above or you could have problems with the computer.And NO they did not put 1.6 rockers on the L98 from the factory.I went with an LT1 cam with 1.6 roller tips,ported and polished my L98 heads,plenum,runners ,and base plus bumped the compression up a little,and it runs good for a daily driven car(summer months). I haven't taken it to the track yet,but I will this spring.
We need Perry Mason
Old Feb 13, 2001 | 01:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, no thirdgen came with 1.6 rockers that I know about. They're all 1.5 non-rollers stamped steel.
I think the LT4 HOT cam is too big for your car. It needs an aftermarket intake, and good headers to perform at its best. I would go to www.sdpc2000.com and do a search for ZZ4 and get their take-off ZZ4 cam for $100. Also do a search on this forum for ZZ4 and see other topics I've replied to about this cam.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 13, 2001 | 02:08 PM
so i take it the zz4 cam isnt quite as radical? will is still give a good lumpy sound to let people know hey that guy has something there either idleing or hittin the fun pedal!!
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
neekolzun
Aug 24, 2015 04:59 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
