spark plug change?
Old Mar 2, 2004 | 04:25 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
spark plug change?
anyone have any tips for removal/install of new sparkplugs and wires on my 92 RS with the LO3?
Old Mar 2, 2004 | 04:33 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
get a can of PB Blaster, and approach from under the car. Took me a good hour, there are a few stubborn ones. Wear safety glasses unless you want shxt in your eyes (dirt, rust, penetrating fluid, etc)
Old Mar 2, 2004 | 04:35 PM
92MaroRS's Avatar
so they are easier to be taken out from the bottom? i know i can do the drivers side easily but the passenger is scaring me. which is why i havent done it yet.
Old Mar 2, 2004 | 04:36 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
fear not, grasshoppa... it's something every man must go through. just imagine how bad it is with headers
Old Mar 2, 2004 | 04:38 PM
92MaroRS's Avatar
ive changed spark plugs before but it was on my truck that had an I6 so that was extreamly easy. i put a new cap and rotor on the car the other day and i had a hell of a time figuring out where each wire ran. i also need to put a new fuel filter in. was gonna do it today but decided not to as i didnt have any penitrating oil.
Old Mar 2, 2004 | 04:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
18436572 in a clockwise fashion
92MaroRS's Avatar
i knew the firing order just that i am use to working on ford motors which number the cyl. different. and plust it was a PITA to see which plug the wires went to.
Old Mar 2, 2004 | 04:41 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
ever consider putting headers on there? they're worth it
Old Mar 2, 2004 | 04:43 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Stick this guy in general tech...
Old Mar 2, 2004 | 06:26 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Disconnect battery prior to removing spark plug. Hate for your tool to fall while working removing # 6 or 8 spark plug. Tool may land on the starter causing a small/large mishap.
Old Mar 2, 2004 | 06:33 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
lol never thought of that...
Old Mar 2, 2004 | 07:49 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
That happened to me when changing spark plugs on my old blazer w/ a 4.3. Was tightening the #6 spark plug and swung the wrench too far and hit the starter. I hit the hot wire and it wound up shorting out the solenoid and giving me a good zap (I was sweaty at the time)
Old Mar 2, 2004 | 08:02 PM
86z/92rs's Avatar
It's all fun and games until someone gets "zapped" sorry, 86WS6_T/A or worst yet, the tool lands on the starter and brake line.....makes a nice fire...anyone have marshmellows? Oh by the way, I have SLP 1 5/8 and removing/installing plugs are much harder now then with stock headers. Need to get the "special tool" soon.
Old Mar 2, 2004 | 08:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I just screw them in by hand and then put a wrench on their bxtchasses
Old Mar 2, 2004 | 09:39 PM
92MaroRS's Avatar
if i had the money i would get headers but i dont. so ill just have to live with the stock manifolds. so can this be done from the top or is it best to go from the bottom.
Old Mar 2, 2004 | 10:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Really? i have SLP's and i dont have a problem. just screw them in hand and tighten them with a 5/8" open end wrench. takes a bit of twisting, but tis not that bad.
Old Mar 2, 2004 | 11:57 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
That's what I do with my Hookers.
BTW Michigan rules.
Old Mar 3, 2004 | 04:58 PM
86z/92rs's Avatar
Some can be done on top and some underneath the car.
Old Mar 3, 2004 | 09:15 PM
92MaroRS's Avatar
could you possibly tell me which ones are best to be taken from the top and which from the bottom?
Old Mar 7, 2004 | 07:56 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
I have headers, and i just replaced all my plugs from the top. i took out the Bosch Platinum 2 plugs(shorter) and replaced them with AC Delcos(longer). It wasnt too hard, i used the socket, but i had to use a wrench on the socket. I replaced all 8 from topside.
To be honest with you I dont see much difference between the delcos and the bosch. My camaro actually is running better with the delcos
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
