Battery Drain/Charging
Old Mar 3, 2004 | 09:19 AM
Jim L. Saylor's Avatar
Car: 1983 z/28 t-top
Engine: 305 Carb LG4
Transmission: 5 speed
Choke light goes out when the car is running. I will check the flow across the terminals...voltage right...
I noticed last night that the volt meter was reading a bit higher than normal...13 amps is at 9:00, this guage was reading the next line up...but as I ran the car for 15-20 minutes, starting, restarting, rev...idle...the guage dropped to 13 even.
Jim
Old Mar 3, 2004 | 03:39 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Sounds normal to me. I work at Tire Kingdom and we have a tester that checks alternator output and the battery, starter, etc...and most cars read 14 to 14.5 volts at a cold idle. 13-15 is probably the normal range. Gotta remember, it takes a minimum of 12 volts to run the car and not drain the battery. So the extra is just to keep the battery charged. The more charged the battery is, the less you'll get out of the alternator, which explains the voltage drop after a little while.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
