wet engine won't start or stops
Old Mar 6, 2004 | 11:47 AM
deva's Avatar
Car: 1983 Z28
I have an 83 Z28 and in the past few years when the engine gets wet it won't start. If even moisture gets into the engine after a rain it will start, but let me sit a few miles down the road. We have replaced the distributor cap, but this has not helped. After the car dries out it's fine again. Any suggestions would be great!
Thanks,
Old Mar 6, 2004 | 03:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Huh, if the engine gets wet it wont start, but if water gets into the engine it will? Im confused.
And how is water getting into the engine? Dont you have a hood?
Old Mar 6, 2004 | 03:18 PM
deva's Avatar
Car: 1983 Z28
I do have a hood on, but if we wash down the engine it won't start for the rest of the day or if it's raining just the moisture can cause it to shut down.
Old Mar 6, 2004 | 03:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
if its carb'd i hope water isnt getting into the carb. That could cause some problems.
Old Mar 6, 2004 | 03:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i would suggest removing the cap and module if its a module on cap design and cleaning all contacts and reassemble with liberal amounts of dielectric greese on all contacts including the wires on the cap and maybe even a little on the end of each plug before reattaching the plugs.. should solve your moisture problem..
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
