How do you tell a 305 from 350?
Old Mar 7, 2004 | 02:32 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Speaking thirdgen engines here, friend of mine doesnt know what he has under the hood, anyway to identify between the two? Thanks.
Old Mar 7, 2004 | 02:35 AM
radiateu2's Avatar
decode the vin number or get the casting numbers on the back of the engine and decode them on www.mortec.com
Old Mar 7, 2004 | 03:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
decoding the VIN only works if its still the stock engine block. The only way to TRULY tell, short of measuring the bore, is via casting number on the side of the block.
Old Mar 7, 2004 | 09:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Drivers side of block, top side right in front of bellhousing mounting face, will be cast in: 5.0L or 5.7L in large letters/numbers.
Can be seen with engine in car, may need a flashlight.
RBob.
Old Mar 7, 2004 | 01:11 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it will only have the displacment cast on the block in litres if its a newer sbc, older ones didnt have that type of marking.
Old Mar 7, 2004 | 03:42 PM
jmd88iroc-z's Avatar
Car: '88 IROC-Z
Engine: 305 tpi
Transmission: 700r4/OD
If the engine came in the vehicle, a 350 should have an "8" in the eighth digit of the VIN, a 305 should have an "e", "f", or "h", I think.
Old Mar 7, 2004 | 04:06 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Then the casting number will be there instead.
Old Mar 7, 2004 | 05:06 PM
Vader's Avatar
If you are unsure if the engine is the original in the vehicle, check the opposite corner deck surface:
Old Mar 7, 2004 | 10:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Damn Vader, what DONT you have pictures of
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
