Head Studs vs. Head Bolts
Old Mar 8, 2004 | 12:24 AM
usa1racing's Avatar
What are the pro's and con's of each, and at what point should I consider using studs over bolts. SBC, 10.7:1, Aluminum heads, Iron block, .630 SR, in a mostly drag strip car with little street use.
Old Mar 8, 2004 | 04:27 AM
ede's Avatar
ede
i'd use them with aluminum block, compression over 12:1, or blown engines. on a thirdgen you have to consider the need to remove a head in the car with studs. you may not have enough clearance around the booster and master cylinder.
Old Mar 8, 2004 | 07:22 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you cant remove the heads with the motor in the car if you use studs..
Old Mar 8, 2004 | 06:23 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
That's not the case in my '86 F-bird, running ARP head studs and the head clears the vacuum booster no problem.
They're great if you end up tearing down the top end often. I had a hard time sealing the coolant passages, be warned! They aren't a tight fit like a head bolt, so the clearances are loose and prone to leaking coolant. The machinist that did my heads says he has trouble sealing them too.
The money is probably better spent on main studs, that's where I would put it in the next engine.
They're great to work with though aside from the sealing problems.
Old Mar 8, 2004 | 06:30 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Studs exert a more consistent clamping force, which is good for higher cylinder pressures, i.e. forced induction. Most other apps, i use bolts like ARP
Old Mar 9, 2004 | 10:28 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Cant get them off because of the booster and such? There are bolts to take off the booster as well, I know that would mean more work. But its not like the end of the world or something.
Old Mar 9, 2004 | 10:40 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Old Mar 9, 2004 | 02:26 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I would definetly use head studs if you're running a factory 400 block. The vent holes in the deck are very close to the threaded head bolt area and are prone to cracking in this area. The beauty of studs is they pull evenly between the head and the deck when clamped down where bolts mainly pull on the deck. If you use threaded deck stiffeners and studs, you've done much to strengthen your deck surface.
If you have a factory four bolt main motor, I would use studs on the mains too. Particularly if it is a 4 bolt 400.
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Aug 25, 2015 12:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
