Edelbrock Intake????
Old Mar 9, 2004 | 08:33 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i am doing my exhaust soon and i'm thinking about doing the intake too. i would need a intake that's has the same dimensions as the stock bcuz i have the functional hood scoop and would like to keep it functional. so i need to know what edelbrock intake is the same height as stock. i thought the RPM is a little higher but i could be wrong. even if it's not edelbrock, but i want performance.
o ya, 84 TA L69 4bbl
Old Mar 9, 2004 | 09:52 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Performer is your only and best bet then. But its not really changing to one, maybe +5hp. Its only a stock replacement manifold.
Old Mar 9, 2004 | 09:54 PM
chio987's Avatar
Engine: 305 4bbl HO
well what other options do i have?
Old Mar 9, 2004 | 10:00 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
The rpm with a drop base filter would be another choice I believe.
Old Mar 10, 2004 | 06:58 AM
chio987's Avatar
Engine: 305 4bbl HO
The rpm with a drop base filter would be another choice I believe. well if i do that then it won't match up with the hood scoop. or would it? if i go with the RPM then what HP increase would i see
Old Mar 10, 2004 | 01:36 PM
chio987's Avatar
Engine: 305 4bbl HO
any other options???
Old Mar 10, 2004 | 08:06 PM
chio987's Avatar
Engine: 305 4bbl HO
anybody......
Old Mar 10, 2004 | 09:16 PM
twistydick's Avatar
Car: 85 berlinetta
Engine: lg4
if youre runnin stock internals, it doesnt make much sense to spend the money on an intake. the stock one works fine, it is the aluminum one , right?youre not gonna get any major hp just by swapping intakes. better spending it on a cam using it towards other mods, etc.
Old Mar 10, 2004 | 09:35 PM
chio987's Avatar
Engine: 305 4bbl HO
i have no idea, it's stock L69 intake. well i doubt i'll go with a cam so i guess i'll forget about it and just do headers
Old Mar 10, 2004 | 09:40 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It's been documented that a "good" intake will net you a+20hp gain. A good intake is a RPM or Airgap RPM. For my money i'd go with a AirGap.
Old Mar 10, 2004 | 09:42 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I can think of a few pros/cons, the Performer accepts both square bore and spread bore carbs... If you're replacing a cast iron monster it saves some weight, and the 2101 has no EGR valve (if you can do away with it) so it cleans up the intake somewhat.
I agree that the money is better spent on headers / exhaust.
Old Mar 10, 2004 | 10:38 PM
Engine: 406
where you gonna find headers and exhaust for $140.00?
Old Mar 10, 2004 | 11:15 PM
twistydick's Avatar
Car: 85 berlinetta
Engine: lg4
it can be spent TOWARDS headers an exhaust......or could find a usedparts deal, ya never know. i got a wrecked 89RS for $200.00.....had headers (hedman), an a 3.23 posi,not to mention good interior, etc. exhaust was screwed up tho. i jus dont see wastin money on an intake that isnt needed, just cause the magazines say ......gain of 5-20 hp.yea, if you gotta iron one,but the aluminum one is fine for stock.
Old Mar 10, 2004 | 11:35 PM
Engine: 406
Yeah I m following you, I guess a fellow just has to sit down and make a plan, decide what he wants,,how much he can spend..then go after it..I agree headers and exhaust are the best upgrade if you plan to stop there...but we ALL Know what ends up happening..
Old Mar 10, 2004 | 11:48 PM
twistydick's Avatar
Car: 85 berlinetta
Engine: lg4
i hear that.......but everytime i plan and save money for mods, something else is brokeded........whats up with that? silly chevy........but with good headers an exhaust, hell be at a good startin point, then if the fever takes over........
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
john204481
Sep 7, 2015 03:22 PM
