1pc rear main seal... Teflon or rubber?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
looking around, i have a choice of two felpro rear main seals...
Fel Pro BS40626 -- Teflon..
or
Fel Pro BS40520 -- Rubber. i found a pic of this one online, its attached below.
so whats the diff between the two, and what would i want? while i have the trans off, i figure NOW is the time to replace the seal on my motor... before it ruins my new T56 clutch.
or
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Where are you buying those Mr. Dude? Im needing to replace my rear seal and cant find them....
Car: 91 Camaro Vert
i just went to advanceautoparts.com and they redirected me to parts america...
athough when i goto get it, im just going to walk into the parts store.. they SHOULD have it in stock...
i figure, since im swapping to a manual, and im going to have the crank empty anyway, i might as well replace the seal.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I got the teflon one a couple weeks back from Jeg's when I ordered a bunch of other stuff...
1992 Trans Am
05-10-2023 07:19 PM
LT1Formula
08-20-2015 09:36 PM
