Chat Room Question
Old Feb 17, 2001 | 11:13 PM
BlueBottleJunky's Avatar
Chat Room Question
Is it up and running? I'm on Web TV so I don't have a browser, but I do have an IRC that can get me there. Does anyone know the server,port, and room name? Thanks
Old Feb 17, 2001 | 11:33 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
If you have mirc, you can goto the server: thirdgen.org port 6667, and yes the web based chatroom is up, normally you can find some of us there around 7-8pm all the way until 12/1am. I am usually in #thirdgen. Hope that helps you.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Feb 17, 2001 | 11:38 PM
branz28...the way my IRC is set-up, I also need the server. The 3 things I need are server,port, and room name. Thanks
Old Feb 17, 2001 | 11:42 PM
hmmmmmmmm either nobodys there or I'm doing something wrong......
Old Feb 18, 2001 | 12:05 AM
87RS402's Avatar
Room name is Thirdgen.
lt1z350
Aug 28, 2015 05:57 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
timonator
Aug 11, 2015 09:56 PM
