Head Gasket
Old Mar 10, 2004 | 04:46 PM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
Head Gasket
Wanting to use a 1094 head gasket on shaved heads and machined block, but I wondered if you use it as is or some compound first? 5.7
Old Mar 10, 2004 | 05:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I sprayed them with aluminum paint because I was using a gasket-scraped-only block surface.
If you have the surfaces machined to their surface finish recommendations, no need for additional chemicals.
Old Mar 10, 2004 | 05:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What do you mean by aluminum paint? Do you have any other suggestions for a scraped surface?
Old Mar 10, 2004 | 05:32 PM
five7kid's Avatar
I mean a real live spray can of aluminum colored paint. It actually has particles of aluminum in it which are soft and fill in gaps.
I used spray Coppercoat on the 396 steel shims. Both engines seem to be doing fine.
Old Mar 10, 2004 | 05:57 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I also used permatex coppercoat on my 1094s. My heads are new aluminum but my block was just scraped clean. I've had no problems so far.
Old Mar 10, 2004 | 06:43 PM
1993GMCPU's Avatar
I saw the copper Permatex spray and asked clerk, he said he did not know. Thanks!
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
