how do you read error codes?
Old Feb 19, 2001 | 07:30 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I looked in the tech articles and couldn't find it there, also looked in the archives until i got tired of looking. I know its simple , can someone explain this to me? thanks.
p.s. 300 posts!! yeah baby, yeeeah!
Pat Hirsz
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Feb 19, 2001 | 09:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Heres the tech article you were lookin for:
<a href="https://www.thirdgen.org/newdesign/faq/thirdgen.shtml#misc">https://www.thirdgen.org/newdesign/faq/thirdgen.shtml#misc</a>
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 19, 2001 | 10:51 PM
Vader's Avatar
88,
If that Tech Article isn't clear enough (it is a little misleading) then you can try this:
First, you'll need to acquire a GM OBD I ECM Diagnostic Trouble Code Retrieval Tool (commonly known as a paper clip to TGO members).
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area. There should be a small rectangular cover over the access hole in the lower dash trim.
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) and it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to open/print the file.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 20, 2001 | 12:45 PM
Car: 88 IROC
Transmission: auto
Thanks a lot Vader! and Ward
Toolsin
Feb 2, 2016 06:55 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
GTAman
Sep 21, 2015 09:57 AM
ZZ42Fast
Aug 30, 2015 02:39 PM
GouldyGTR
Aug 21, 2015 10:43 PM
