Stuck lifter?
Old Mar 15, 2004 | 05:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Stuck lifter?
When the car is cold as in cold weather, when I start it up it sounds like one of the rockers have fallen on an bouncing around in the cover. Okay, a little exadurated but it is pretty loud and it does sound like metal to metal contact. After the car runs for a little bit and heats up it goes away a little bit. My theory that one of the lifters are stuck or collaped and when the oil pressure builds up then it starts work. What do you guys think?
Old Mar 15, 2004 | 07:18 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Hydrolic lifters will bleed down to a point. So yes they will be a little noisier on startup until they pump up w/ oil again...
Old Mar 15, 2004 | 11:10 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
This isn't just a little noisey. I know this is not normal. I can sit in the car with the windows rolled up and the radio blasting and I can still hear it.
Old Mar 15, 2004 | 11:20 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
same problem
i have,been told it could also be a dirty injector?!?!
Old Mar 15, 2004 | 11:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I thought about that but I believe a dirty injector would be more of a tick.
Old Mar 16, 2004 | 01:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How long does it take for your oil pressure to buildup? minutes? seconds? Have you removed the valve covers to make sure everything is as they are supposed to be under there?
Old Mar 16, 2004 | 10:17 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I removed the valve covers and everything looked okay. It only happens when it is cold outside. It only happens for a few minutes until the oil pressure and engine temp rises.
Old Mar 16, 2004 | 02:38 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
ive got the same problem........and now ive developed a miss/vibration around 1800rpm ........i think one of my lifters in #8 cyl finally colapsed because its showing 150 psi and 175 on all the other cylinders on the compression test......i checked for broken rings or a cracked piston but found nothing.....
tmellott89
Oct 14, 2015 02:06 PM
skinny z
Oct 5, 2015 06:23 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ctoledo0834
Sep 18, 2015 04:16 PM
dimented24x7
Sep 6, 2015 03:51 PM
