Can I clean my spark plugs?
Old Feb 18, 2001 | 07:11 PM
Vader's Avatar
I was just wondering how many miles you think are left in this plug if I clean and re-gap it.
I just thought you might get a charge out of that one. It seems that we could all benefit somewhat if we'd just <h1>lighten up a little!</h1>
Maybe spring won't get here soon enough....
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 18, 2001 | 07:51 PM
ede's Avatar
ede
vader a little preventive maintance goes a long way.
ICON Motorsports
1st & 3rd
Old Feb 18, 2001 | 08:14 PM
GearHead1973's Avatar
Try a little J-B Weld or the fix all solution Duct Tape.
Old Feb 18, 2001 | 08:20 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Ain't nothing that Super Glue Gel won't fix
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Feb 18, 2001 | 09:22 PM
Enkil's Avatar
You know, this post got me thinkin'...
Where does all that voltage go?
I know it jumps the gap, but then where? I didn't think it went back the way it came, but I also didn't think it just dissapated in the engine block either. So.. ??? heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 18, 2001 | 09:29 PM
sven86berlinetta's Avatar
Why clean and regap? It looks fine to me!
Old Feb 18, 2001 | 10:06 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GearHead1973:
Try a little J-B Weld or the fix all solution Duct Tape. </font>
That's right!
J-B BABY
Old Feb 18, 2001 | 11:33 PM
Guest
Guest
Posts: n/a
The above suggestions and a little POR-15 will do wonders.
Old Feb 19, 2001 | 12:09 AM
burnoutrpm's Avatar
it looks great man just use some scoth tape!!!! that'll fix anything!!! to clean them try wd-40!!! how the f*** did you do that any way i mean....dammmmmn!!!!!!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 19, 2001 | 03:46 PM
DSouthern's Avatar
I've magnified this plug picture a 100 times and what I have discovered is that this black burned up area actually contains an incinerated 5.0 Mustang door handle!!!
Old Feb 19, 2001 | 04:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The car that came out of obviously still ran, so I guess it's still good...
Looks like somebody needs to fix the coolant leak that made the shell rust through. Then you could just epoxy it back together, put it in, and it should be good for another 100,000 mile tune-up interval!
ICON Motorsports
Old Feb 19, 2001 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"If it moves and it isn't supposed to, duct tape it. If it doesn't move and it's supposed to, WD-40 it."
Old Feb 19, 2001 | 09:34 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Jeez im surprised you got that out in only two pieces... :P
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 20, 2001 | 12:59 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Did somebody say Elmer's? Vader I find your lack of faith disturbing - any decent garden-variety intergalactic warlord could just "use the force" and make his own plugs out of 1' square former crustangs...
"Among so many conflicting ideas and so many different perpectives, the honest man is confused and distressed and the skeptic becomes wicked...Since one must take sides, one might as well choose the side that is victorious, the side which devastates, loots, and burns. Considering the alternative, it is better to eat than to be eaten."
Napoleon I
Old Feb 20, 2001 | 09:23 AM
Box of Rocks's Avatar
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
"If it moves and it isn't supposed to, duct tape it. If it doesn't move and it's supposed to, WD-40 it."</font>
And if it still won't move, flip the oxygen **** up to "CUT", blast it until it's white hot, and beat the ever-lovin' beejeezus out of it with a BF HAMMER.
That's right by cracky - hammer, don't hurt it.
Signed "El Destructo" .......aka
BOR
Old Feb 20, 2001 | 12:19 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
HAHAHAHA - it's hammertime!!
and then spray with wd-40, because here, we're all too legit to spit.
Old Feb 20, 2001 | 12:47 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by I ROCK:
</font>
I'm with I ROCK, Use the force Vader.
Remember, Behind every successful man is a suprised mother-in-law.
-Gallager
Qsac
Old Feb 20, 2001 | 09:10 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
<font face="Verdana, Arial" size="2">Originally posted by Enkil:
</font>
Actually the spark jumps from the block up into the plugs then up the wires to the distributer then to the coil. Since it is isolated at the coil the only place it goes is into a reverse induction and some emi/rmi.
Old Feb 20, 2001 | 09:27 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
Actually the spark jumps from the block up into the plugs then up the wires to the distributer then to the coil. Since it is isolated at the coil the only place it goes is into a reverse induction and some emi/rmi.</font>
Joel,
Actually, the conventional theory of electron flow would indicate that the spark would travel as you describe - from negative to positive. However, don't overlook the fact that the coil is essentially a transformer operating on pulsed DC as opposed to AC (which is really quite the same thing as far as the coil is concerned).
Regardless of the current, the collapsing magnetic field around a conductor will induce a current in a direction opposite that of the direction of the current used to build the magnetic field. (Remember the left-hand rule of thumb for inductors?)
Because of this, you should remember that the secondary voltage/current of the coil is actually phased in reverse of the primary voltage/current. The center terminal of the coil becomes highly negative, to the range of 15KV or higher, and the "grounded" side of the coil secondary winding is actually at a positive potential compared to the ungrounded end of the winding. This causes the induced current to flow from the coil center terminal, along the distibutor paths, through the spark plug wire and plug center electrode, to the more positive ground electrode.
I just thought that maybe you forgot your elementary inductor/transformer theory. It doesn't make a great deal of difference in an ignition system, but it becomes very important in high voltage/large KVA commercial substations.
Later,
Vader
Old Feb 20, 2001 | 09:55 PM
JoelOl75's Avatar
Ahh.. Yes! The power souce is interupted and the field collapses inducing a reverse charge. I forgot all about that. Thats right up there with hysteresis and eddy currents.
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
