Help Fast!!!!!!!!!!!!!!!!!!
Old Mar 19, 2004 | 11:01 AM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
Ok, yesterday my engine ran fine. it's an 85 LB9 305 TPI. i was thinking someone must have put something in my tank because it is running like sh*t. no ses light showed and i even checked for new ones. the only one that shows is 32, which only shows on cold starts cuz the proms for the 85 sucked that year. it seems as if the maf sensor is disconnected but it's not. it has no power and it runs really rough and sluggish. i am sure you guys have had this problem before and i really could use some advice as to what it could be. i am going to try some different things later today and if no luck then i'm dropping it off to my mechanic.
Old Mar 19, 2004 | 11:02 AM
Car: 85 Z28
Engine: 305 LB9 TPI
almost forgot! it could be the gas i bought too. i'm gonna get some water remover now and try it out.
Old Mar 19, 2004 | 11:09 AM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
possible bad plug wire/s?
Old Mar 24, 2004 | 11:03 AM
Car: 85 Z28
Engine: 305 LB9 TPI
the water remover really worked. i took it to a differnet station and put higher octane. it runs fine now.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
