Question & Story
Old Mar 21, 2004 | 05:43 PM
jiggajiveturkey's Avatar
Car: 88' Firebird
Engine: 2.8L
Question & Story
Ok, there is what I would describe as a grinding coming from my right front tire as a make hard left turns. Seems to me that this could only be a bad bearing.
For some reason I decided to let my friend (who is a mechanic) change the bearings for me. Long story short it took him about 30 - 45 min to change the bearings on the front 2 wheels. After driving a day or so I realize that the sound is still there (maybe not as bad).
SO... my 2 questions are: Considering the time he took do you think the work was actually completed. What other problems could be the source of this noise?
Thanks!
Old Mar 22, 2004 | 12:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd check for the rim hitting something like the a-arm.
Old Mar 22, 2004 | 04:23 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
if the ball joints are worn the wheel could be folding just enough to touch the tie rod end.
if you want to check that jack the wheel up on the A arm (so the wheel is under load) and push on the tire at the 12 oclock and 6 oclock posistions you should have no play. and you can also check your tie rod play by doing the same pushing technique at the 3 and 9 position.
Old Mar 22, 2004 | 04:32 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
my front right wheel grinds wicked bad when i turn to left, but the fender is bent up like a mother.
Old Mar 23, 2004 | 06:54 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
GTA88 it sounds like you need wheel bearings. using the method i have up listed above check that wheel for the bearings also pull the wheel off and see if there is any scoring on the back side of the rim or tire
neilb
Oct 4, 2018 12:36 AM
fasteddi
Sep 2, 2015 10:29 AM
stickychinsac
Aug 31, 2015 06:06 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
