Which is best? Z28 or IROC?
Old Feb 23, 2001 | 05:32 PM
nesluopetan's Avatar
I know that the Z28 and iroc is better than the RS, but whats the main differences between the Z28 and IROC? my z28 has everything , power windows, doors, air, etc. so whats the main differences? when did the iroc come out? just curious guys. thanks
nate
Old Feb 23, 2001 | 05:36 PM
Dan87IROC-Z's Avatar
The "IROC" Camaros were available from 85-90. But from 85-87, the IROC was just a package option on the Z28. In 88, the IROC replaced the Z28 as the top of the line edition of the Camaros. But in the early years the IROCs were "better" than the Z28s because they were avavilble with the 350s and better looking rims and such.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 23, 2001 | 06:19 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I've often heard that bigger swaybars and Bilstien struts were standard on all IROCs but an option for Z28s. I do know my IROC has the biggest baddest looking swaybar I've ever seen. It's like an inch and half or more in diameter.
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
Old Feb 23, 2001 | 06:26 PM
Chris'86RS's Avatar
Its pretty much the engine type and sometimes you get more options when you buy the better known name which is the IROC...but mostly it was engine the bigger engone was avaliable in the IROC and not in the Z28.
Old Feb 23, 2001 | 06:27 PM
Chris'86RS's Avatar
Its pretty much the engine type and sometimes you get more options when you buy the better known name which is the IROC...but mostly it was the size of the engine and the the bigger engine was avaliable in the IROC and not in the Z28.
Old Feb 23, 2001 | 06:40 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
IROC's have better suspension, 1 color including GFX, IROC rims, and the option of a 350 TPI engine.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
