Help- What in this picture DON'T i need?
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
I don't have a/c or heat and would like to take out what i don't need......please tell me which wires and boxes, units, whatever i don't need. Keep in mind its carb'd.
Thanks.......
Thanks.......
the big black a/c / heater box can come out.
u might want to make a panel to cover up the hole in the firewall to make things look better.
its comes out with all the bolts around the perimeter and then a few inside the car under the passengers side dash panel.
Car: '82 Z28
Engine: 350HO
Transmission: M4
about the only one in the picture that it looks like you don't need is this one but don't cut it off, just hid it, or stuff it back on the other side of the firewall under the dash.
if you ever want to put a/c back on, or ever want to sell the car, the orginal wiring in tact is nice to have. also, if you want your heater to work, your going to have to get a a/c delete box instead of the big black box for the a/c
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
are you doing away with the heater all togather? if you are you could make a cover out of plexi glass and paint it to match the engine bay.
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 12, 2015 11:33 AM
