Front Main Seal???
Old Feb 20, 2001 | 05:24 PM
jaydog's Avatar
Front Main Seal???
Hello, how much will it cost to have my front main seal fixed?
What about the rear seal?
Please help me!! I need to know soon....
Jason
Old Feb 20, 2001 | 06:54 PM
ede's Avatar
ede
help if you told us what sort of car it was on, if it is a car at all. since you didn't give us much information to go on i'll guess 25 dollars plus parts.
ICON Motorsports
1st & 3rd
Old Feb 20, 2001 | 07:01 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
There is no front main seal on an SBC. Only an oil pan front seal and timing chain cover seal. Which of these do you mean (and as ede said, what engine)?
George P. Lara
1984 "L69 A4"
Soon to be 357, T5, 3.70
1994 LT1 M6
SCCA, SCFB, SC3GFB
Old Feb 21, 2001 | 02:33 PM
jaydog's Avatar
It is a 91 Z28 TPI 305 ......... Ok, well I was told that the front main seal was going out and needed repair. Whatever seal that is? They said the entire engine would have to be pulled?? Help please, Thanks, Jason
Oh and what about the rear seal?
Jay 91 Z28
Old Feb 21, 2001 | 03:27 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Rear seal can't be replaced in the car easily. The front seal would have to be the oil pan to timing chain cover seal. That can be replaced without pulling motor, but requires the help of some sealant. How much? No idea.
Old Feb 22, 2001 | 12:44 AM
yellowiroc's Avatar
the front main seal is easy...anyone telling you to pull the motor is trying to scare you. I'd suggest a biatch slap across their face. Pulling an engine on a third-gen is a PAIN.
86 IROC 305 TPI LB9 700R4 W/ Shift kit, K & N, Flowmaster gutted cat 95 Z tips, airfoil, 160 thermo, removed emissions, Summit cam kit 442 lift springs and lifters, ADS super chip, Summit timing chain, modified MAFS, tranny cooler, polished rims, Good Year yellow letter nascar 235/55 tires, polished runners and plenum, 145 Speedo, remote start, keyless entry, alarm, yellow neons underneath.
Old Feb 22, 2001 | 10:15 AM
Mike89GTA's Avatar
Probably about $600 to have the front "timing chain seal" replaced. There is no front main seal since the "main" refers to the thing that the seal sits in on the rear of the engine, not the fact that it is the "main" way to keep the oil from leaking out.
Of course around here, for a reasonable estimate of what you will probably pay multiply what they tell you by 2.5 so it would probably cost $1500.
Old Feb 23, 2001 | 10:58 AM
yellowiroc's Avatar
what dope are you smoking?
Old Feb 23, 2001 | 11:10 AM
R.O.B.'s Avatar
Getting back to the real world, if it is the timing cover seal that you need replaced, the gasket kit costs about $20. But you also need to drop the oil pan to do it. If the oil pan gasket needs replaced, theres another $15. Labor is your only factor now, if you do it yourself, it'll take about 5 hours, with alot of beer breaks inbetween. Also, if you have 80,000 plus miles on that engine, you should also replace the timing chain while your at it. A good double roller one can be had for about $30. Another good idea is to replace the water pump while your at it, since it too has to be removed, about $35 for this. Don't forget that you will also need to rent a harmonic balancer remover/installer tool.
As for the rear seal, yes, this is a major pain to do, if your not to good with the wrench, take it to the shop.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
[This message has been edited by R.O.B. (edited February 23, 2001).]
Old Feb 24, 2001 | 07:26 AM
Mike89GTA's Avatar
Around here that's what it costs. Ok maybe that's a little bit more but around here everything is expensive. They charge you at least twice as much for parts and labor is horrible.
Old Feb 24, 2001 | 07:31 AM
Mike89GTA's Avatar
BTW notice he said they wanted to remove the entire engine. I don't think my estimate is far off at all in that case.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
