Felpro 1 piece oil pan gasket..
Old Mar 23, 2004 | 06:02 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I need to replace my oil pan, car has a 2 piece rms 350, anybody know the part number? Also has anyone had any bad experience with these? recommendations?
Old Mar 23, 2004 | 09:10 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Im not sure of the part number, mine is a 1pc seal. The engine isnt running yet, but the gasket looks and fits great, I dont see how you can go wrong with a 1pc gasket over the older stock style.
Old Mar 24, 2004 | 12:30 AM
OMINOUS_87's Avatar
Its the only way to go, accept nothing less.
Old Mar 24, 2004 | 04:53 AM
ede's Avatar
ede
1885 is for up to74 blocks can't find PN for 75 to 85 blocks
1886 is for one piece rear seal blocks
Old Mar 24, 2004 | 05:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Can you even get a one piece oil pan gasket for a 2 piece RMS?
Old Mar 24, 2004 | 05:35 AM
ede's Avatar
ede
Old Mar 24, 2004 | 05:53 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Old Mar 24, 2004 | 06:49 AM
ronterry's Avatar
Car: '94 Corvette
Chevrolet: 1975-85 262-400, two-piece rear main seal, one-piece, Accu-Seal Pro, oil pan gasket. $34.99
Summit Part# SCE-211090
Never heard anything bad about 1 piece oil pan gaskets. I only wish I used one when I assembled my block.
Ron
Old Mar 24, 2004 | 08:15 AM
ede's Avatar
ede
one piece oil pan gaskets is all i use any more. i should of said the PNs were from fel pro.
Old Mar 24, 2004 | 02:06 PM
89RsPower!'s Avatar
whats the difference between 74 and below and 75-85? are the 75-85 blocks the pass side dipstick 2 piece blocks? what other differences are there for the oil pan? I know the 305 in my dads el camino has the pass side dipstick.....
Old Mar 24, 2004 | 02:55 PM
ede's Avatar
ede
not sure if it's the dip stick location or the height of the timing cover lip, or both.
Old Mar 24, 2004 | 05:30 PM
ronterry's Avatar
Car: '94 Corvette
Yeap 'ede' I think it does have something to do with the lip height in the front.
AS far as the dipstick, I think that's the pre/post 1980 deal.
As far as the pan gasket goes, there's probably a swoop on the passenger side regaurdless of pre/post 80'. Since the pre '80 driver side dipstick goes into the block you don't need a swoop on the driver side, but with the post '80 block where the dipstick goes directly into the pan, you diffently need that little swoop.
Ron
Old Sep 28, 2004 | 01:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My experience...Fel Pro one piece pan gaskt. = junk (leaks) Get a GM
Old Sep 28, 2004 | 05:33 AM
ede's Avatar
ede
don most i've ever run was around 30,000 miles on a 4.3 with no problems. i know in the big picture 30,000 miles isn't all that much on an engine or gasket.
Old Sep 28, 2004 | 12:05 PM
ljnowell's Avatar
hmm, here i am still using cork valve cover gaskets and oil pan gaskets. They never leak, so I wont bother changing.
Old Sep 28, 2004 | 12:22 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I dont have one leak with my one piece gasket although my friend did but it turned out to be an installation error as one of the edges was folded over.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
