Please ID two sensors in block
Old Mar 28, 2004 | 07:35 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I'm still doing my 395 cu in stroker motor. I bought a ZZ4 block for the stroker. My stock L98 block has two sensors in the block.
One is on the pass side, in front of the starter motor, what is this one?
The second one is on the drivers side of the block, just above the oil filter. It has a long 2 to 3" neck to it. What is this one?
I think that I will buy new sensors for these two, instead of reusing them. After all, they are 17 years old.
TIA.
Old Mar 28, 2004 | 07:48 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The first one in front of the starter (directly above the oil pan seal, roughly centered front to back on the block) is your knock sensor... The second one above your oil filter that is about 3-4" long is your oil pressure sending unit (tells the gauge inside)...
Old Mar 28, 2004 | 11:49 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
sure that it's not a tep sender? all thought the water temp sender IS on the head..... not the block.
Old Mar 29, 2004 | 08:19 AM
thirdgen88's Avatar
Car: 1995 Corvette
I don't understand your sentence..
Old Mar 29, 2004 | 08:23 AM
Car: 1982 Trans Am
Engine: 383 chevy
hmmm let's try again... when I'm sober. are you sure it's not the water temp sender? although the water temp sender IS on the passenger side head.... not the block. make sense?
Old Mar 29, 2004 | 09:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
water temp sensor for gauge is on drivers side head.
water temp sensor for fan is on passenger side head.
water temp sensor for ECM is in intake manifold.
in the waterjacket on the BLOCK on the passenger side is the knock sensor.
directly above oil filter on rear drivers side on the block is the oil pressure sensor/switch. earlier 3rdgens had 2 oil sending units. one in the same place for the switch, the other is on the rear china wall of the block. looks like a big canister.
Old Mar 29, 2004 | 10:17 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the replies.
I was inquiring about the two sensors that are located in the block. Mrdude, I do have the second oil pressure unit located in the top side of the rear china wall.
I think that I got the correct answers above.
The sensors in the heads as listed above are correct to the best of my knowledge. The sensor in the drivers side heads between cylinders 1 & 3 is the water temp gauge sensor. I know this for a fact because when that wire did not get hooked up right, I had no water temp on my gauge in the car.
Another question:
The new block is the ZZ4 block, the part number ends in 123 (I think). The block is at the machine shop now, does anyone know if the block is drill and tap for the above mentions sensors in the block???? (I know, I should have checked for this BEFORE I dropped off the block.)
And I assume that I can get equivalent sensors at AutoZone as opposed to buying more expensive sensors at a Chevy dealership.
Old Mar 29, 2004 | 10:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Another question:
yes and yes.
its drilled and tapped for the sensors already, and you can buy replacements at autozone
Old Mar 29, 2004 | 10:26 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Mrdude, you are the man! thanks
thirdgen88, thank you for your help also, I did not want to leave you out on the thanks.
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
