I have the 9 bolt and want better gears, what do I do
What is the easiest thing for me to do. I hate these 3.27(? or 3.23 whichever it is with the 9 bolt) I know gears are 400 dollars for the 9 bolt, would it be cheaper just to get a new 10 bolt with 3.73 or 4.10 gears???Any suggestions appriciated
Bright red 87 GTA with I have stock 3.27 gears,stock converter,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 10,000 volt coil,No cat, flowmaster 2 chamber mufflers, hedman full length headers, edelbrock cam with 488/501
Car: 1985 Trans Am
Axle/Gears: 3.70
My gears for the BW9 bolt were only $265 from DTS. Install ended up being kinda pricey, but that was just a bad choice on my part.
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
-=ICON Motorsports=-
to find out more
Where is DTS??? where can I order those gears?
BTW, what is the ratio on ur gears and what kind of difference did they make?
[This message has been edited by Brandog87GTA (edited March 01, 2001).]
Car: 1985 Trans Am
Axle/Gears: 3.70
I'll have to look around for the website. Full name is Drive Train Specialists I think. They're out of Michigan.
Went from 3.27 to 3.70. No real numbers to show the difference but it was definetly something I could feel.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Look at the Drivetrain/Transmission forum, there are several threads about gears for 9-bolts.
here are the links:
www.ring-pinion.com
www.drivetrainspecialists.com
www.calgear.com
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
here are the links:
www.ring-pinion.com
www.calgear.com
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
In 1987 (the year your car was made), GM only put TWO different 9-bolt rears in the Firebirds!! One with 2.77 gears and the other with 3.45 gears! The only way to tell for sure which you have is to get the numbers off the rear end!! Unfortunately, if you have the 2.77 gears, the ONLY gears you can upgrade to are the 3.08's that GM sells!! If you have the 3.45 rear then you're in luck and can upgrade w/out switching to a 10 bolt rear!!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Hedman Shorty Headers, Stock casting pocket ported heads (2.02/1.60 - 65cc), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
