Oil on top of intake manifold??
Old Mar 1, 2001 | 10:08 PM
theformula's Avatar
Check out my mods below. I have been finding oil on top of my intake manifold. Tonight it was a mini puddle.
I have no idea how this could happen. For the supercharger install I had to put breathers on my valve covers and plug my PCV and other hole on valve cover. I don't know if that is of relevance or not.
Any ideas?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited March 01, 2001).]
Old Mar 1, 2001 | 10:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Oil usually comes up the intake manifold bolt threads.
The trick is to use liquid teflon sealer on the bolts.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 1, 2001 | 10:16 PM
theformula's Avatar
Hmm, the intake has never been off the car. I did an injector swap....I'm burning oil every few hundred miles
Old Mar 1, 2001 | 11:11 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
The oil will creep up the bolts even if its never been off.
Are you sure its not leaking somewhere else??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
[This message has been edited by Engineboy (edited March 01, 2001).]
Old Mar 1, 2001 | 11:41 PM
burnoutrpm's Avatar
the guy is right its either the manifold bolt or the gaskets arent sealed right. try gasket sealant or teflon tape around the threads of the bolts in question.
89 firebird formula
356 9:1 compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
882 casting 202/160 valves
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 1, 2001 | 11:42 PM
burnoutrpm's Avatar
89 firebird formula
356 9:1 compression
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Old Mar 2, 2001 | 02:24 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Where exactly is the oil accumulating?
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 2, 2001 | 11:33 AM
theformula's Avatar
Right under the first 2 runners (closest to throttle body) on the passenger side
Old Mar 2, 2001 | 12:23 PM
Blue92's Avatar
Hey I don't know if this is your problem, but my father-in-law has a paxton on his truck. He is a clean freak and he says he cleans his motor once a week because of all the oil that blows all over his engine. That might be where it is coming from. Just a thought
http://albums.photopoint.com/j/View?...781&p=29492901 http://albums.photopoint.com/j/View?...781&p=29492902 http://albums.photopoint.com/j/View?...781&p=29495767
"DriveHarder"
Stock 305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Old Mar 2, 2001 | 02:04 PM
JakeJr's Avatar
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by theformula:
Right under the first 2 runners (closest to throttle body) on the passenger side</font>
Are you sure it's engine oil? I read some reports of the A/C compressor throwing oil in that area on Vettes.
Is there any sign of oil on the hood directly above where the oil is accumulating?
Just some thoughts.
Jake
Old Mar 2, 2001 | 02:31 PM
theformula's Avatar
Well, I'm not sure what the hell it is. The only thing I do know it is not, is fuel.
It just started happening after the injector swap. Maybe oil is getting in through the runner bolts....
[This message has been edited by theformula (edited March 02, 2001).]
Old Mar 2, 2001 | 02:38 PM
theformula's Avatar
You know what. Something occured to me when I saw WARDS post about his oil cap flying off. I have aftermarket valve covers as well along with the "push in" oil cap. I suspect oil may be splashing up from there.... or possibly through my breathers?
Old Mar 2, 2001 | 08:15 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
If you don't have any baffes under the breathers you will get oil from them, they fill up with oil and leak.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Mar 2, 2001 | 10:33 PM
Damon's Avatar
Ya know, dropping a blower on a motor will only make crankcase blow-by vapor problems worse, due to massivly elevated cylinder pressures/temps.
I agree with the leaky-bolt idea but it could also be just a shot intake gasket. Or a vlave cover gasket gone bad. but usually if it's puddling on the intake it's a weepy bolt or a shot intake gasket.
BTW- make sure your PCV valve and hose are working properly. Clogged PCV valves can cause problems similar to this. Doubt it's the problem, but it's easy to check.
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
