Freakin oil filler cap!!! Lost another one!!
Old Mar 2, 2001 | 10:38 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I have aftermarket chrome valve covers, and they have just a push-in type oil filler cap. How the heck can i keep it on?! ive lost 2 now; I guess they fall out when I hit a bump or something. I swear im gonna glue it in...
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Mar 2, 2001 | 10:44 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Thats shouldn't be a problem if you are using a good grommet. Otherwise ??
...ed
Old Mar 2, 2001 | 10:46 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
It doesnt have a grommet. there is just a hole in the valve cover, and the oil filler cap has a rubber piece on the bottom that pressses into the hole. You know the $4.00 chrome Mr Gasket oild filler cap that autozone sells? its that one.
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
Old Mar 2, 2001 | 12:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's nothing wrong with your PVC system (excessive pressure under valve covers), is there? I have an oil fill cap by Spectre that's been hanging in there pretty strongly.. got it from Summit Racing for $7.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 2, 2001 | 02:33 PM
Jza's Avatar
Jza
PCV
Old Mar 2, 2001 | 02:36 PM
theformula's Avatar
I have the same type Ward. Though mine doesnt come off, I am now beginning to suspect it is causing the oil all over my intake. I think it may be splashing up...
Look at my other post
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 2, 2001 | 03:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oops! Thanks!
Old Mar 2, 2001 | 09:31 PM
FastBroker's Avatar
Check your PCV system, as was suggested. Also, realize that USUALLY only one of the valve cover holes has a baffle under it to prevent direct oil splash upon whatever is in the hole. w/o the baffle, funny things can happen, and can be exacerbated by an improperly performing PCV system.
FYI, you have to use a baffled hole for the PCV valve itself, for obvious reasons.
Old Mar 2, 2001 | 11:16 PM
84TransAm's Avatar
I've got the same type from Autozone. Never had a problem. Dunno what to say
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Mar 3, 2001 | 08:10 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I lost four before I made a strap that goes from the two valve cover bolts over the cap. Do you have the GMPP valve covers? I do. I now have a GM cap, but haven't had a chance to use it yet.
BTW, there is nothing wrong with my PCV system. Lots of vacuum at the valve.
Old Mar 3, 2001 | 09:00 PM
mikeage2's Avatar
yeah and blow-by could be doing it too.my friend had to run a breather cap on each v/c before he quit losing his caps
86 camaro:was a v6 car,now its going to be a v-8 5.7l!!
350:cylinders bored .040 over.a little over 9:1 compression(getting a blower some day when im rich lol)line bored.deck is milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194? intake valves(not 2.02( ),pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(well` at least they look nice lol)and intrepids all day makes me drink too much
good job security though
im always on the lookout for cheapv-8 t-5,s
and t-56 setups.they must be cheap.i dont care of they need rebuild,as long as they arent totally blown
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 21, 2015 09:32 AM
