Question ??
Old Apr 7, 2004 | 12:42 AM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
Question ??
Hi...i realy want to know what is the difference between a two pieces real main seal and a one piece...is this only on 350 or on 305 too?? and...is it on roller bloc only??
Other question...Roller bloc mean that GM made stock roller lifter en rocker??? so many question to ask!!
Thnx alot
Patrick
Old Apr 7, 2004 | 01:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The rear seals are just those. 1 and 2 pieces. THe 2 piece you put the top half in the block, install the crank and whatnot, and the lower half rests on that. Its just another place for oil to leak out of.
The 1 piece forms a complete ring around the rear of the crank. it is one less place for oil to leak out of.
As for the "roller block" designate, no it does not refer to the rockers being of roller design. It refers to the lifter type. roller means that there are little rollers on the end of the lifter that act as a bearing point and greatly reduce friction.
The roller tappet is on the left, flat tappet on the right. You can see the roller design of the lifter and how that "rolls" on the lobe.
As for your questons...just ask or do a search. or do a search, then ask
Old Apr 7, 2004 | 09:07 AM
ChallengeR's Avatar
Car: Trans Am 87
Thnx Stekman!! now i'm less stupid and i know about the roller lifter but...the block change if its roller??? or just the lifter..because i heard people say that he want a roller block....???
Thnx
Old Apr 7, 2004 | 10:50 AM
Morley's Avatar
Thnx
The block needs to be made for the factory lifter retainer to use the factory roller lifters, hence "roller block".
Old Apr 7, 2004 | 12:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The lifters on the left are roller and the ones on the right are flat tappet. You had that switched. Good pic.
Old Apr 7, 2004 | 12:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Indeed i did mix those up, my error. Thanks for the correction shifty.
That is what was meant when he said the lifter valley was tapped in 3 places. As you can see the 3 places that are raised and tapped. Thats where the lifter retainer plate gest bolted down.
That is the other thing that designates a roller block. The cam retainer plate. That catches the little step on the nose of the cam and acts as a catch to prevent the cam from walking forward and thrusting against the timing cover. Obviously, the block would need to have 2 holes drilled and tapped in the front of it in order for that to be present.
Thats the 'roller cam' nose. Notice the stepped nose profile. That just centers itself inside the cam retainer plate. That retainer plate catches the step and prevents any forward motion that a roller cam may have. The other way that cam walk is prevented is with a cam button.
Old Apr 7, 2004 | 01:52 PM
ChallengeR's Avatar
Car: Trans Am 87
A BIG thanks to you guys that's the best answer that i can have!!!
Thnx
Patrick
Old Apr 7, 2004 | 04:48 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you can however retrofit an older non-roller block to roller.
Old Apr 7, 2004 | 09:53 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup. People do it all the time. The 400 block is very popular with modern stuff on it.
Old Apr 7, 2004 | 10:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
But if you do, be sure to ask yourself:
Does the price justify the performance gains? (everyone has their own answers to that)
Old Apr 7, 2004 | 10:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It goes way beyond performace. Smooth idles, tons of cam selections for muit port set-ups, self allinging valve train, not having to adjust lash every other day, etc etc are just a few of the many advantages.
Old Apr 7, 2004 | 10:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
True. I have a solid roller setup. I dont have the luxury of all that lash stuff. But yes, generally the gains can offset the costs. But to some that are on a budget, they arent first upgrade on the list.
Old Apr 7, 2004 | 11:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Now that I agree with.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
