My 1991 RS Wont start PLEASE HELP!!
Old Apr 7, 2004 | 09:47 PM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
I just bought a 1991 Camaro RS. Brought it home it ran fine I was working on it cleaning things up and all after that it still started fine. Today I went outside cranked the car up and it started right away put in park and it stalled. Now it wont start anymore. I tried dropping a little fuel into the TBI and nothing. What could this be. PLease help I need this car runing again asap.
Old Apr 7, 2004 | 09:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
does it crank? Do the injectors spray when cranking? Do you have spark?
Old Apr 7, 2004 | 10:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Does it turn over? Do you have a v6 or LO3? Your fuel pump could have peaced out.
Old Apr 7, 2004 | 10:22 PM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
No spark it cranks fine and i dropped gas in so if it was the pump then it would have started when i dropped some gas. Where is the module on this lo3 v-8??
Old Apr 7, 2004 | 10:30 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
So you are saying there is no spark? Does fuel come out of your injectors. Putting gas in the TBI unit does not mean it will always start. You may want to buy a pressure tester to make sure your pump is not dead. That is a very common problem with these cars.
Old Apr 7, 2004 | 10:38 PM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
No no fuel from the injectors and no spark. My other tbi did that ounce and i dropped some gas in the tbi and it started until it used all the gas. This one just cranks and no spark and no gas I drop gas and still nothing. Where is the module on this car??
Old Apr 8, 2004 | 09:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If by module you mean the ignition module, under the distributor cap. Good possibility it is that or the distributor pickup coil (also in the distributor).
If you meant ECM it is under the dash on the passenger side.
RBob.
Old Apr 8, 2004 | 11:05 AM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
GOOD JOB GUYS!!! I changed the module and pick up coil and it cranked right up and ran beatifully. Thanks a million to all that gave there $.02!
Old Apr 8, 2004 | 11:40 AM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
order yourself the MSD super HEI ignition module, ive had it on 3 motors and it still works like it is brand new.
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Cripley
Aug 17, 2015 03:35 PM
