Bought my cam lifter and spring today!!
Old Apr 8, 2004 | 01:19 AM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
Hi...i have baught my cam spring and lifter today...and i just want to know if it have any difficulty that can stop me in my installation...i know that i have to remove the intake, the timing cover, the fuel pump....any other thing that i have to know or any hint to do??? and another question...my timing cover does have anny timing mark and i've seen new cover but the timing mark were not on it too...it was in a bag and you can install it yourself...how can i install the timing mark on the timing cover??? i put the first on compression and i put the 0 at the red dot on the balancer???
Thnx guys
Patrick
P.S. my engine was a LG4 305 1987
Old Apr 8, 2004 | 07:56 AM
ede's Avatar
ede
bring the #1 piston to TDC and match the timing tab to the mark on the dampner
Old Apr 8, 2004 | 01:09 PM
ChallengeR's Avatar
Car: Trans Am 87
Ok thnx...and i heard that ia have to drop the oil pan to remove the timing cover...that's true?
Old Apr 8, 2004 | 01:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You dont have to completely remove it. When i ran a 1 pc timing cover i undid the front bolts and loosened the rear ones. This lets the pan drop enough to remove the cover.
Old Apr 8, 2004 | 05:02 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
I'd recommned that while you have the timing cover off, you take a grinder to it and grind off that lip so you wont have to drop the oil pan again.
well worth the 30minutes and a few sparks in the eyes
Old Apr 8, 2004 | 05:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Or get a 2 piece timing cover.
Old Apr 11, 2004 | 01:08 AM
ChallengeR's Avatar
Car: Trans Am 87
Some guys tell me that he does it without removing the cover..anyone here had does this??? thats the last thing to do...all the rest were removed and ready to accept the new friend
Old Apr 11, 2004 | 01:55 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If its a 1 pc cover, it has t be removed. Theres no other way to get the cam out.
sweet_87_iroc
Sep 25, 2015 10:01 PM
86IROC112
Sep 7, 2015 01:37 PM
86White_T/A305
Aug 17, 2015 12:16 AM
johanlindgren
Aug 16, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
