Cloyes timing chain orientation
Old Mar 4, 2001 | 06:50 PM
Black82Z's Avatar
I bought a Cloyes timing chain about a year ago and put it in my 305 at 0* but now i do not know which symbol(circle,square,triangle)is the 4* advance or 4* retarded if anyone knows this can they please help, I need this info to put my new 350 together. thankyou
82 Z28 had LG4-305"
now has 350 carb
edelbrock performer, headman headers,chevy 1.6:1 roller rockers,rebuilt heads-3 angle valve job-prof.bowl blend-new valves,seats,3"flowmaster, Mac high flow cat
MSD6AL,700-R4--B&M shift kit, B&M tranny cooler. Sub-frame connectors, boxed lower control arms and torque arm. 1.5" front sway bar, rebuilt carb, 4" K&N, no emissions equipment, new BFgoodrich radial T/A's--215/65 front 255/60 rear
RADIO-- premier Deh-p300
2-10"kicker SPLs,ZR240,premier 434x(4 way), custom built fiberglass box for subs. pioneer 6X9 & 4X6, grant GT steering wheel
Old Mar 5, 2001 | 02:06 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I'd had to go from memory on something like that because if I'm wrong, you'd end up doing the job all over again and you'd hate me for life.
See if Cloyes has a website, or call one of the companies that sells the set, Summit, PAW, etc. to see if one of the guys will pull one of the installation sheets and tell you.
If your local auto parts store(s) sells 'em, try there too.
Hopefully someone that has a sheet handy will look it up for you and post the info you need. I've got one around here somewhere, but I haven't seen mine in quite a while.
If you can't get the info, shoot me a line and I start looking through all my saved installation papers for it.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited March 05, 2001).]
Old Mar 5, 2001 | 01:55 PM
Black82Z's Avatar
Thanks Jake, I'll try what you suggested
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
