power coating
Old Apr 9, 2004 | 12:22 AM
pskel350's Avatar
power coating
is there anyway to powder coat or chrome a water pump without ruining the seals in it? my water pump bearings just took a crap, but i dont want to put a plain cast iron pump back on. or should i spend the extra $130 on a polished aluminum piece?
Old Apr 9, 2004 | 02:11 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not just use high-gloss engine paint?
Old Apr 9, 2004 | 06:03 AM
ede's Avatar
ede
i don't think powder coating would hurt seals or bearings. even if it does take the pump apart before you have it done and reassemble when it's coated. i think paint is another option.
Old Apr 9, 2004 | 09:00 AM
pskel350's Avatar
paint just isnt as nice, and since everything else on the engine is either polished or powder coated i would like to keep with the theme...
when the shop puts the water pump in the oven to cure the powder coat, it wont melt the seals?
Old Apr 9, 2004 | 09:10 AM
ede's Avatar
ede
ask them, be best to take seals and bearings out, actually i think they all use a sealed bearing.
Old Apr 9, 2004 | 09:22 AM
Vader's Avatar
Ede's right. Most SBC pumps use a single cartidge bearign with seals. If you're dead set on powder coat, disassemble the pump and have at it.
Old Apr 9, 2004 | 12:26 PM
pskel350's Avatar
yeah i think it would be best to disassemble it
one shop told me that i wouldnt need to worry about the seals, and one said that they wont powder coat water pumps just for that reason.
Old Apr 9, 2004 | 12:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Powder coating involves baking; seems like that would be hard on rubber parts.
It would definitely be best to disassemble it first. Mybe get new bearings & seals while you're at it, so it's basically renewed while you're at it.... it would suck to spend a bunch of time & money on doing all that, then have the WP go bad a month later, and have to be replaced anyway.
Old Apr 9, 2004 | 01:02 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
We do powder coating here at the shop, and you definatly need to disasemble to powdercoat.
Old Apr 9, 2004 | 02:22 PM
pskel350's Avatar
thank you, that is what i needed to know
RB83L69, the bearings already went out on mine, thats why im looking into getting a better looking replacement
Old Apr 10, 2004 | 10:39 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i may have jus got lucky but i powder coated mine myself this winter assembled and have had any probs i jus baked it on a little lower temp
Old Apr 12, 2004 | 08:00 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
FYI for ya guys: They bake it @ 400+ degrees for like 1 1/2 hours. Anyway thats how long they were doing handrail and such that our shop were getting coated. I was wanting to get my new HSR (will be here tuesday) coated, but have heard of guys intakes getting tweaked in the process.
diana227vegas
Jul 8, 2016 12:27 AM
tom1985
Apr 19, 2016 07:55 AM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
