Replacing fuel pump...anything i should watch out for?
Old Mar 8, 2001 | 01:43 AM
Josh 91RS's Avatar
Im going to be replacing the fuel pump this weekend. Is there any problems or anything i might watch out for? Anything that came up unexpected for anyone??Thanks guys.
Old Mar 8, 2001 | 08:42 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I just did my fuel pump swap last weekend. Nothing unexpected, just about 10 hours of work. I suggest raising the rear of the car as far up as you can, disconnect the exhaust at the catalytice converter, drop the rear end by removing the shocks, traction bar, etc. and than just pull the exhaust out once you drop the rear end. I think that's the best way to do it. Its pretty straighforward, nothing unexpected where i had to run to the autostore for special parts or anything. If your tank is full, you might want to get a syphoning kit, cause i just used my mouth to suck on the hose in the gas tank, and it wasn't very pleasant - but worked good. Dropping the tank isn't that bad if you lift your car enough.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears, slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Mar 8, 2001 | 10:17 AM
jobryan26's Avatar
Yea a sore back. It's a PITA.
'87 Trans Am
305 TPI:
160 Degree Theremostat
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Spark Plugs
Custom Ram Air with K&N
Old Mar 8, 2001 | 10:25 AM
burnoutrpm's Avatar
yeah if its fuel injected then its going to be FUN... you have to move the exhaust,drop most of the back suspension componets,shocks have to drop,then comes the gas tank thats worlds of FUN!!if its got any gas in it RUN IT OUT FIRST!!, even then its a bitch to get the tank out you'll have to bend the filler neck and then try and twist the tank sort fo to get it out!! F U N!!!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 8, 2001 | 02:24 PM
Car: 88 IROC
Transmission: auto
it took me about 10 mins to get the tank out once i had all the bolts off and another 10 to put it back in. Just make sure you raise your back end high enough and you'll be fine. also, you will have to disconnect the brake line when you drop the differential. If you did not have to disconnect it after you dropped the diff. then it probably means that you don't have enough room to take the tank out and you should lift the car up some more.
Old Mar 8, 2001 | 03:35 PM
MATEOZ28's Avatar
Get a roto zip and cut a hole in the top of the rear section above the tank. Replace pump. Put some hinges on the cut out metal and tape it well when replacing. Replace carpet and NEVER have to worry about dropping the tank again. Just open the whole backup when you need a new pump. It works fine.
Old Mar 8, 2001 | 05:42 PM
Car: 88 IROC
Transmission: auto
I wouldn't suggest things like that without a warning of a possible explosion. You are gonna be making a lot of sparks right above the gas tank. Have a fire extinguisher handy if you decide to do it that way.
Old Mar 8, 2001 | 08:24 PM
Dsaint's Avatar
I did it Mateos way except I did it with a dremel.
Old Mar 9, 2001 | 09:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Try not to re-use the stock "pulsator", between the fuel pump and the fuel sending unit (where the pump attaches). The seals in it can leak over time, and cause pressure to drop. I found this out AFTER re-using my stock pulsator! I wondered why that hose and self-tightening clamps came with the fuel pump...
Search the TPI board for "pulsator", you'll find a bunch of info on it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
