Any tips for working with AN fittings
Old Mar 9, 2001 | 10:44 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I remeber last time I played with them how much of a bitch it was to get the fitting on the s.s. hose. Any tips with working with this stuff. And should I teflon tape the ends?
Thank you gents
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
-=ICON Motorsports=-
Old Mar 9, 2001 | 12:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
<font face="Verdana, Arial" size="2">Originally posted by Karps TA:
</font>
Ditto esp when the SS hose starts to come apart. I taped my ends even though they say not too.
Old Mar 9, 2001 | 02:55 PM
Biochem's Avatar
Car: 2002 SOM z28
Here's a tip for ya... let someone who knows what the fork they're doing work on your car for a change! AHAHAHAAAA
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
Old Mar 9, 2001 | 03:10 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Well in that case Ray who do you send your car to??
Old Mar 9, 2001 | 03:26 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I have AN fittings throughout my car and they can be a pain to work with. Whenever cutting braided hose make sure you wrap it with electrical tape to prevent it from fraying. Also, make sure you use assembly lube. It make getting the hose into the fitting MUCH easier. Also don't use teflon tape or paste on the fittings, there is no need to.
Old Mar 9, 2001 | 04:18 PM
merf23's Avatar
What are you cutting them with. I tape them and carefully use a cut-off wheel with a piece of nylon or wood dowel in the hose. There is also a product ive seen which is a fixture with a chisel built in for cutting the hose. I dont do that much of it so i never bought one.
1984 Z28 (L69) monochrome tangerine orange with IROC decals and hood
1987 IROC wheels with Goodyear GSC's
305 from 87 IROC with 1994 LT1 cam (203/208 .450/.460")
performer intake with holley 600 (#1850)
Qjet is in the works
dynomax cat-back
non WC T-5 with 0.73 5th
3.27 nine-bolt
Old Mar 9, 2001 | 04:20 PM
ede's Avatar
ede
when i need one i figure out the length and what type fitting i want and go to an industrial hose supplier and have them make them for me, they use crimp on fittings way cheaper and a lot easier to do. cost about 5 dollars a hose for labor and the crimp on fittings are about 1/2 the cost of the screw type.
ICON Motorsports
1st & 3rd
Old Mar 10, 2001 | 07:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ray Godman uses a diamond-edge cutoff saw, like a tile blade, with masking tape. That keeps the ends from fraying before you even get started. A hacksaw almost always causes trouble.
I like ede's suggestion... that's how I handle alot of things, is to get somebody with the right tool to do it for me when I realize that I don't have the one it takes.
ICON Motorsports
Jeremys87
Jul 14, 2022 09:08 PM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
matthew911
Aug 12, 2015 09:38 AM
milk
Aug 10, 2015 06:26 PM
