081 Casting flow numbers?
Old Apr 22, 2004 | 12:06 PM
Project Z's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 Bolt, 3.23 Posi
Anyone have the cfm numbers for the stock 081 castings from the 305cid. I'm trying to estimate some power figures and make some dicisions on parts for the rebuild of this engine. No reason overbuilding for higher rpm if the heads can't deliver the flow required at 6000 - 7000 rpm.
The machine shop had the heads and did a multiangle valve job and some bowl work, but they don't have a flow bench. No porting or matching yet because I'm not sure that it would be worth the effort.
Old Apr 22, 2004 | 01:12 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Get Vader's templates for these heads and use them as your guide. I believe his runners came out to around 177 cc, and flow immensely better than the stock numbers. Somewhere around Vortec numbers. Whether that is good for 6000 or 7000 rpm I don't know.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
PurelyPMD
May 5, 2016 04:57 PM
355tpipickup
Sep 13, 2015 11:35 PM
Springster
Sep 13, 2015 01:38 PM
john204481
Sep 7, 2015 03:22 PM
