Question maybe one might know?
Old Apr 24, 2004 | 11:53 PM
Hal3246's Avatar
Car: 1986 P. Firebird T/A
Engine: Stock v8 305 TPI
Axle/Gears: N/A
What would be the stock 305's HP and Rear end Torque in a Firebird (not T/A, or Formula) v8 carbed? This is a question only for the stock 305 sold off the assembly line, I don't know where to look up the info.... heh... Thanks to those who answer this question. Also does anyone know the "estimated" hp/torque drop from a manifold leak, a decent leak
Old Apr 25, 2004 | 12:01 AM
Morley's Avatar
All depends on the year and which carbed 305.
HP loss from a vacuum leak? Big leak=considerable loss small leak= minute loss, more of an idle issue with small leaks.
Old Apr 25, 2004 | 12:09 AM
Hal3246's Avatar
Axle/Gears: N/A
Shoot, well if there is a bad leak there is a considerable loss could it also help in a fuel air mixture problem at startup? Also I have had a studdering startup, grey smoke, smell like exaust mostly but I also smell some gas, but only at startup you can see the grey smoke from under the hood? Could that be the O2 Sensor? Maybe it just being a lazy o2 on its way out...arg. Anyways is there a place I could look it up, I know that my 305 carbed tbi 4bl.
Old Apr 25, 2004 | 12:17 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Anywhere from 140-190hp.
Old Apr 25, 2004 | 12:30 AM
Hal3246's Avatar
Axle/Gears: N/A
Thanks, would you know maybe an estamated torque at the rear end? I don't know the rear, I know it's posi stock axel and drivetrain. although for an auto, I don't know if it possible with stock auto, I started in 1st (first time, thought someone was following me) jabbed into 2nd and let off gas and jab gas as I switched into ODrive, the rear "chirped" so I don't know if it is stock, or even if it should be possible for one to "chirp" the rear with an auto
Old Apr 25, 2004 | 10:45 AM
Hal3246's Avatar
Axle/Gears: N/A
No one would know an "ESTIMATION" of what the stock torgue could be? I didn't ask for exact...
Old Apr 25, 2004 | 11:58 AM
Hal3246's Avatar
Axle/Gears: N/A
how about a site I could go to, mabye a maker that would have the stock specs on my firebird... heh
Old Apr 25, 2004 | 05:18 PM
Morley's Avatar
Well, the stock torque was 275 on the 305 TPI's, so figure about 200 at the wheels.
Never really paid much attention to the carbed engines specs, or TBI for that matter.
Old Apr 25, 2004 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Apr 25, 2004 | 10:49 PM
Hal3246's Avatar
Axle/Gears: N/A
WOW thanks alot, that is just what I wanted, I know it can be found on the door, but I tried to read it and it seemed to be somewhat scratched out, what is estimated stock weight of the "firebird" (1987) I guess my engine is an LG4 v8 4bl but I don't know if it is the one with 165 or 170, but it really isn't much of a difference, but the stock weight would help, alot... (estimated)
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
