Time For A Tune Up!!! What Have You Guys Done
Old Mar 10, 2001 | 10:52 PM
FiReBReTHa's Avatar
Ok, its time for a tune up,
I have a Pont V-8 305 91, (68,000) miles
Now What should i replace? take care of etc, Full Bang,
What brand? if you have part numbers, Itd be much appreciated,
Thanx GUYS!!!!
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Mar 10, 2001 | 11:51 PM
Dan87IROC-Z's Avatar
I would get an MSD, Accel or AC/Delco cap and rotor kit for your distirbutor. Also get a new set of spark plugs, I like the AC/Delco rapid fires. You should also invest in a good set of spark plug wires. I run the Accel 8.8 300+ race wires, I got them from Jegs for like $65. One piece of advice is to use one brand for all your ignition parts, either all MSD, all AC or all Acell. Also replace all your fluids. Your coolant, engine oil and filter, tranny oil and filter, rear end fluids. If your air filters are dirty, change them, or if they are K&Ns, clean them. Also you can lube your chassis, check your emissions systems, your PCV valve, what else am I forgetting guys??
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 11, 2001 | 04:29 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
fuel filter, tire pressure, windshield washer fluid, brakes, tv cable, fuel injector cleaner, i dunno
Old Mar 11, 2001 | 08:02 AM
Chuck Everly's Avatar
Moving to Tech/General Engine board. You should get more help for this question there.
Thanks,
Chuck
Old Mar 11, 2001 | 08:55 AM
Enkil's Avatar
As quoted from Vader...
Enkil,
You can start with something like this. Use what you want. It's not copyrighted yet:
A basic tune-up MUST include:
Cooling system inspection;
Clean or replace spark plugs;
Ignition wire testing;
Distributor cap/rotor (if you don't have the OptiSpark);
PCV valve cleaning or replacement;
Air filter;
Cleaning the IAC;
Checking/setting TPS voltage;
Check/adjust minimum air rate;
Check/adjust timing;
Code scan;
The proper steps in fuel injector system service are:
Check fuel pump operating pressure and volume.
Test pressure regulator for operation and leakage.
Flush entire fuel rail and upper fuel injector screens to include pressure regulator.
Clean fuel injectors.
Decarbon engine assembly.
Clean throttle plate and idle air control (IAC) passages.
Check minimum air flow rate and adjust if needed.
Relearn onboard computer.
Cleaning injectors is not a "basic" tune-up procedure.
To clean the injectors and system correctly takes about two hours if you're experienced and have all the right equipment, about four hours longer if it is your first time and/or you only have basic tools and instruments. When performing this, you should also test fuel pump output volume and pressure - these are critical to proper operation of the system. You can have the fuel system power-flushed, but most of us don't have the equipment to perform this at home. This seems to be a good procedure if done correctly.
The advantage to the old-fashioned way of cleaning injectors is that you get to actually see the injector screens and spray tips. And while you have everything disassembled, you can easily do the intake plenum modifications that the factory should have done. You can also clean up that mess under the plenum and fuel rails, and get a good look at the EGR, which should be pulled and inspected if you're already that far. Once you perform this, you'll appreciate the need for using good fuel and keeping a clean fuel filter.
Scheduled Service
It's not just changing the oil. This is a generic outline of GM recommended service procedures and intervals. Verify the correct interval an procedure with your owner's or shop manual.
Monthly
Check Fluid Levels
Check Lighting and Horn
Tire Pressure
3000 Mile Service
Oil and filter change
7500 Mile Service
Chassis Lube, Fluid Levels
15000 Mile Service
Tire Rotation
Hose Inspection
Underbody Flush / Inspection
Body Lubrication
Door Hinges, Latches, Lock Cylinders
Hood & Trunk Hinges, Latches
Weatherstrips and Bushings
30000 Mile Service
Differential Service
Belt Inspection
Front Wheel Bearing Repack *
36000 Miles Service
Transmission Service
Cooling System Service
Flush & Refill
Condenser/Radiator Cleaning
Front and Rear Brake Service
Tune Up Service
Replace Spark Plugs
Spark Plug Wire Testing
Fuel Filter
Distributor Cap, Rotor, Coil Test
Air Filter
Vacuum Hose/Fuel system Inspection
PCV system Inspection
50000 Mile Service
Front Shock Absorbers
Rear Shock Absorbers
Emissions Service
Evaporative Canister Filter
Oxygen Sensor Replacement
Determine your car's actual mileage, then determine if each of these procedures have been done at the correct intervals. If you don't have a hard receipt showing a service within the specified mileage, you'll need to do it now. If your car has 60,000 miles and it hasn't had a distributor cap in the last 30,000 miles, you need to replace it.
(Excerpted from my pending booklet)
Old Mar 11, 2001 | 09:59 PM
FiReBReTHa's Avatar
ok,
Now, more directly, what products have performed best for you guys,
Model numbers are verrrryy appreciated.
Dis Cap
Rotor
Accel Wires i can get 8.8 for 43$
oil
hmm...
Oh yea, whats the "TV" Cable ?
And the IAC?
And the tps was at like ".7"
Somehting close to that
If someone can tell me where to get accel stuff for best price id much appriciate
91 FireBird 305 V-8
no true mods,
GheTTo Riggers INC.
Old Mar 11, 2001 | 11:05 PM
burnoutrpm's Avatar
read my signature thats how i TUNED mine up!!!hehehehehe
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 11, 2001 | 11:58 PM
theformula's Avatar
i say stick with ac delco tune up stuff. You won't have the problems I have
Old Mar 12, 2001 | 03:00 AM
Car: 90 Camaro RS
Engine: 305 TBI
TV cable is for the tranny....if not "adjusted" can cause tranny probs. iac.
well you know what...i was gonna tell you but i ahve a TBI..so its all different locations. my IAC was in my air cleaner,and the tv cable is right below the aircleaner on mine...i have no idea where anything is on a TPI
Old Mar 12, 2001 | 06:39 AM
FiReBReTHa's Avatar
Thnx Blackbeauty, its k, were together 305TBI
No ACCEL??
Old Mar 13, 2001 | 03:02 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Black Beauty:
fuel filter
</font>
Fuel filter, Fuel filter, Fuel filter.
Change that thing often, I buy them by the case off of my friends comercial account for around $2 a piece. Use the allied, it comes in a orange box and looks just like a fram. It is a fram, just doesn't have the name, allied makes fram. Duh. A restricted fuel filter can cost you an easy 30 hp or more and several mpg. The money you save from better fuel milage will more than pay for changing the filter every 5000 miles.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Jake_92RS
Aug 11, 2015 10:39 AM
