restated: OIL PAN TROUBLE CAN SOMEONE HELP??
Old Mar 12, 2001 | 11:28 AM
pat85yellowroc's Avatar
ok. im sorry about the attn: that i posted. it wasnt meant to be that way. i would like help from anyone that can help me. here is my previous post........alright, i just bought a 91z, and i was going to do an oil change yesterday. i decided to use some of that engine cleaner that you add to your crankcase. well i put it in and let it run, then i jacked the car up to change the oil and some MORON that had the car before me screwed up the oil drain plug. its stripped to a circle and it looks like someone welded it to the pan. it wont come out. its a 305 and ill be doing an engine swap in a little less than a year. it just has to make it till then, but should i drill my own hole and put in a self tapping plug? i dont have the time or money to put in a new oil pan. dont have 6-8 hours to put a new one on, and i dont really want to pull that 305 and put it back in. what should i do?? like i said, i ground around the edge of the plug but it WILL NOT TURN. if grind the head off how can i get the rest of it out??
Old Mar 12, 2001 | 11:37 AM
Bort62's Avatar
They actually welded it to the pan ?
Hmm.
What about Drilling it out, and retapping the hole for a Piep plug ? as far as getting th "rest" of it out, You may be out of luck there.
if you could break the weld, you would be in alot better shape.
Try drilling it for an EZ out.
Going to be an interesting undertaking )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 12, 2001 | 06:11 PM
Vader's Avatar
Pat,
Usually, one topic thread will do the trick...
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 12, 2001 | 06:23 PM
ede's Avatar
ede
well i'm not sure where your other thread is, but as vader said one post per problem will usually work, sometimes you have to wait a while. if the plug is welded in the pan you can take a cut off disk and remove the weld and the unscrew the plug. if it's striped you could tap it the next size bigger and use a new plug. if the plug is striped replace the plug. if the threads are stripped in the pan there would be several options to fixing them, all involving welding and a fair amount of skill.
ICON Motorsports
1st & 3rd
Old Mar 12, 2001 | 06:46 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Didn't we cover this already??
There is no easy answer, you've got a problem, with few solutions.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited March 12, 2001).]
Old Mar 12, 2001 | 06:54 PM
Mike89GTA's Avatar
Just go buy one of those pumps that you attach to a hand drill and siphon the old oil out through the dipstick tube. A LOT easier than pulling the engine, even if you have to change the oil a couple times to make sure all that cleaner stuff is out.
[This message has been edited by Mike89GTA (edited March 12, 2001).]
Old Mar 12, 2001 | 07:05 PM
JETHROIROC's Avatar
Good call, Mike. Just get a suction gun and eventually you'll get most of it out. I use one after I drop the tranny pan and replace the filter to suck 3.5 quarts out, put new in, drive around, stop, suck...until I've got about 95% new fluid in the tranny (I have an Excel spreadsheet that calculates how many times you have to do it if anyone's interested). Pull the filter and change it, and then when you get more time take it to someone who can fix it or, depending on your skill, the pan may end up looking like swiss cheese .
Old Mar 12, 2001 | 07:44 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
I GOT IT! The dipstick, it already goes to the oil pan, just drain the oil out that way. Sorry, only thing i could think of.
"Oh yeah, well i'm taller"
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
Old Mar 13, 2001 | 03:44 AM
well, thanks to those of you who tried to help. as for there being more than one topic, i brought it up the second time because the way i phrased it the first time sent everyone into fits. sorry.
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
